Class 150 Driver training fault question
Killtrox
5 Oct 2021
Morpeth
Currently doing MDD training and we are learning about Train Wire 4 on the class 150.
We were given the following fault to figure as homework.
"TW4 Problem.
You are on a 150/1. You are unable to get brake release. You carry out your fault finding as we discussed and there are no visual indications of what could be the fault. You enter the rear cab and CAN get brake release. So you return to the leading cab and are still unable to get brake release. What is the fault?
It’s not the jumper cable."
At first I thought the EBS was lifted in the rear cab as the wording seemed the rear cab hadn't been checked yet but apparently its visual indications throughout the entire train.
Could it be a faulty DSD pedal in the leading cab ??
ThePeakNed
6 Dec 2021
Salop
The fact the question has been focused solely around a scenario occurring in the front cab of a 150/1 (specifically) leads me to believe it’s MCB related, as I know there are certain conditions where you can’t get brake release in one end but can the other, based on a 150/1.
I’d take a guess at Train Control MCB has tripped.
Killtrox
5 Oct 2021
Morpeth
That would come under the visual indicators, which have all been checked/not showing signs of a fault which made me think EBS raised in rear cab as the wording suggested that cab hadn't been checked yet or a faulty DSD as that shouldn't affect the rear cab?
westcoaster
4 Dec 2006
DTOS A or B
Motor alternator !
Silent AWS/AWS fault
Been a long time since I signed sprinters
On 319's A, B,C MCB's
Alternator
Brake control
Control positive
GC class B1
19 Jun 2021
East midlands
I don’t know much about sprinters but from my limited knowledge could the fault be either the brake negative in the leading cab or end of train relay fault in the trailing cab.
skyhigh
14 Sep 2014
And a coupling fault you wouldn’t get brake release in the other end because TW4 would be still broken because it would be looking for the other unit
Precisely. Same as if you pressed couple while in neutral with no unit there. No brake release in either cab.
Efini92
14 Dec 2016
"TW4 Problem.
Dsd or AWS mcb has tripped in that cab.
irish_rail
30 Oct 2013
Plymouth
From my experience this is almost always a reverser fault. Playing around a bit with the F and R switch cures it.
Efini92
14 Dec 2016
You’d know about an AWS MCB though, as the sunflower wouldn’t be illuminated, wouldn’t it?
Yeah it would sound either. Plus the mcb tripping is a visual indication, doh.
It’s the DSD.
GC class B1
19 Jun 2021
East midlands
Motor alternator !
Alternator
Brake control
Control positive
Sprinters don’t have motor alternators. They have a 24volt DC control system. The AWS is 24 volt and the batteries are charged by an engine driven alternator similar to a car.
Although I am not knowledgeable in the electrical systems of sprinters, from my fault finding experience I can eliminate systems that are common to both cabs such as brake control units, door interlocks or passenger communication. The fault is likely to be with a component or wiring that is specific to one cab, probably the leading cab as the trailing cab seems to be operating normally. This could include the master controller, power brake controller or safety system.
LowLevel
26 Oct 2013
Out of interest given the prevailing opinion is DSD, do the 150s have vigilance fitted which would make a fault of this sort more obvious or not?
skyhigh
14 Sep 2014
All /2s do, some /1s have been modified to have vigilance fitted.
sw1ller
4 Jan 2013
Well, you had 60 seconds to work it out….. just call maintenance. The delay has to be attributed to someone. Don’t know why TOCs spend so much time on this then you don’t get the chance to sort it out yourself in the real world.
secretsquirels
23 Aug 2019
Bodmin Parkway
Turns out the answer was faulty DSD
Never in doubt
Call maintenance? When the person who asked the original question is training to be an MDD? So they’ll be ringing themselves then
LowLevel
26 Oct 2013
Never in doubt
Depot drivers just drive the things surely, if they jack in transit Phone a Friend has to be the way to go :lol:
