Class 326 and Class 768 for Rail Operations Group 'Orion'
superalbs
Verified Rep - Superalbs Travels
3 Jul 2014
Exeter
Just seen on Facebook pics of 57312 hauling a converted Class 319 in the ROG Onion livery.
I was expecting this to be a Class 769/5, but it seems they have decided to reclassify these as Class 768 now.
Working seems to be 1212 Eastleigh Arlington to Wembley H.S., running quite delayed:
Would share a pic, but it's in a private Facebook group.
superalbs
3 Jul 2014
Exeter
Also hearing that the ROG Class 319s are now to be Class 326s!
XAM2175
8 Jun 2016
There's also a suggestion that their 319s will be reclassified as 326s.
(though I hope that choice of font does not stay long - it's not the most legible!)
I'd hazard a guess that it fails the spirit of the vehicle marking standard, even if it satisfies the letter - but I note that while RIS-2453-RST (Vehicle Registration, Marking and Numbering) makes specific demands for the format of the vehicle number, it doesn't include any requirements at all for the appearance of the set number other than where it's positioned.
43096
23 Nov 2015
The vehicle number is in the same style: if you zoom in on the photo linked in post #6 above it's visible.
adc82140
10 May 2008
I suppose being parcels carriers they are now very similar to a class 325, hence class 326. As I understand it, despite having a networker shaped cab, the 325s are pretty much 319s with roller shutters.
Domh245
6 Apr 2013
nowhere
It's surprising that there isn't anything in the standard about it being clear and legible!
To be fair though, the longer I've looked at it, the more I've adapted. I think that possibly the real issue is that they've crammed it in between the grille and the blue edge so the 1 is barely legible against the edge - move it to the other side and there's less of an issue (or uncommit their major sin of slapping a yellow box on the front, ignoring the 'lines' of the unit where the yellow should naturally fall!). That and the 7, which ideally would have a sloping 'tail' than a straight down one
XAM2175
8 Jun 2016
For comparison, this is what's said about vehicle numbers:
Part 4 - Data to be Displayed on Rail Vehicles
4.2: Display of GB operational number (TOPS)
4.2.1: For existing GB registered vehicles, the GB operational number (TOPS) shall:
a) Be displayed on each side of the rail vehicle using a minimum of 80 mm high Arabic numerals;
b) Be written in a sans serif font;
c) Contrast with the background; and
d) Not be positioned higher than 2 m above rail level.
Rationale
G 4.2.2: The minimum size, position and font specified enables clear recognition by operational staff.
But this is all that's said about set numbers:
4.5: Display of the multiple unit and fixed formation set identification number
4.5.1: Multiple unit sets shall have the multiple unit set identification number displayed in full, externally on each end of the set.
4.5.2: The display of the multiple unit set identification number shall be on the front of the cab or, if not on the front of the cab, on both sides of the vehicle at the cab end.
Rationale
G 4.5.3: The display of the multiple unit set identification numbering is necessary for operational purposes.
Guidance
G 4.5.5: It is permissible for the class identifier element of the multiple unit set identification number to be separated by a short space, for example 465 201.
Personally I'd say that the way they've done it for 768001 is unacceptable, but it's not like it's my problem!
fgwrich
15 Apr 2009
Hampshire
Original post notes that they seem to have been reclassified from 769/5 to 768
Photographic evidence on flickr as well of the renumbering (though I hope that choice of font does not stay long - it's not the most legible!)
It's not just the font that irks me, but the slapdash positioning of the yellow panel - it's like the Batman Mask. It just would have looked that little bit better if they'd done it like the Northern Electrics livery in my opinion:
skyhigh
14 Sep 2014
I normally try to stay out of paint wibble, but you're right - the way they've done that is awful
Domh245
6 Apr 2013
nowhere
That is surprising. I'd have thought that there might be some generic catch-all line in there somewhere about "all markings should be legible etc etc" but evidently not. Worst bit is that even if such a point did exist, and was the same as the current requirements on the vehicle numbers, that would technically meet it (as evidenced by the use of the same font for the vehicle number, underneath the first window back from the cab)
100% - funnily enough I was complaining about this exact thing yesterday on a different thread!
pdeaves
14 Sep 2014
Gateway to the South West
I disagree. I think the yellow and font is just jarring enough to match the bold 'hey, look at me' image on the rest of the unit. I quite like it. Shows we're all different, I suppose!
SeanG
4 May 2013
I also stay out of paint wibble - its their unit so they can paint it how they like.
But this just seems like a photoshop job where they haven't bothered to use the curve of the front end panel and just have stuck a rectangle on
Is there actually any official confirmation that either class currently exist?
Other than it (768) appearing in a photo, what official confirmation would you normally expect? What confirmation did you get when eg 769 first appeared?
ExRes
16 Dec 2012
Back in Sussex
Having now seen a photo with 768 on the front of the unit then fair enough, but class 326? why should I not challenge something which is nothing more than supposition?
I suppose it depends how much credence you give Richard Clinnick’s reporting. Is he generally on the ball?
507021
19 Feb 2015
Chester
Class 326 and 768 designations have been allocated to these fleets because the vehicles which make up the units have been reclassified*, which means they can no longer be considered as a Class 319 or 769 subclass respectively. The Class 321 freight demonstrator has not had the same treatment, so has retained its existing TOPS number and classification.
* From DTSO-PMSO-TSOL-DTSO to DTV-PMV-TV-DTV.
Journeyman
16 Apr 2014
Correct. The bodyshells and traction equipment are all the same as the 319.
Domh245
6 Apr 2013
nowhere
To be fair, the Orion units were 319s and 769s until recently. I wouldn't be surprised to see the 321 demonstrator similarly renumbered before it goes into service for the reasons you note
