Class 365 PBC Unit and PIS system
WMasterJedi
23 Nov 2023
England
One thing worth noting, there seem to be two sets of messages for the SE. Do we presume an update was done at the point where the 365s were concentrated on the Victoria to Ramsgate / Dover Priory route, in particular where they started regularly detaching and attaching at Faversham?
I do have another EPROM board with GT North chips which have identical hand written labels with the same year however the South East chips are printed and not hand written.
Do you think its worth reading those to see if they are different?
365 Networker
19 Jul 2019
I would certainly be interested to see if there is any difference.
8 Apr 2010
I have renamed all of the .BIN files into .VOX and then converted them using NCH Switch!
Download here: https://drive.google.com/drive/folders/1K6kqcFouNsGY0IP4tbZ3afXhCU4X9mvN?usp=sharing
Thanks a lot for all of this. However the format is still incorrect - if it was really VOX ADPCM, the audio would be completely clear. My guess is that it could be either MS ADPCM or IMA ADPCM, with the same 16kHz sample rate and 4-bit encoding. I suspect the Piccadilly Line announcements that we have yet to properly convert to also be in one of these formats. Another clue is that some of the ScotRail files are encoded as MS ADPCM. Looking around the internet it seems to be incredibly hard to find software able to convert these formats back to WAV, although it appears there are some command line tools if you are skilled in that area. If not those formats then it could be one of the many other versions of ADPCM - including possibly a bespoke version.
Thanks a lot for all of this. However the format is still incorrect - if it was really VOX ADPCM, the audio would be completely clear. My guess is that it could be either MS ADPCM or IMA ADPCM, with the same 16kHz sample rate and 4-bit encoding. This is actually the same format I suspect the Piccadilly Line announcements to be in. Looking around the internet it seems to be incredibly hard to find software able to convert these formats back to WAV, although it appears there are some command line tools if you are skilled in that area. If not those formats then it could be one of the many other versions of ADPCM - including possibly a bespoke version.
Interesting that there’s potential similarity to the Piccadilly Line, as both the 365 and 73 stock refurbishments were around the same time - although the actual sound files for the Piccadilly Line were done a few years later (the Piccadilly Line originally had a a male voice from the time the trains were refurbished). Could be a coincidence though.
Worth a go. It might be the case that the extra announcements were simply added, as the difference seems to only relate to the Dover / Ramsgate section. What may well be different is the program which assembles everything.
Indeed we know there was a tweak at some point, as originally the WAGN units played “The next station is Finsbury Park” on the northbound approach to Potters Bar, however this was corrected at some point as it never happened latterly.
So guessing at some point there was a software change, possibly both fleets done at the same time, hence why there’s SE messages on the GN eprom. After that it seems something happened and there were never any subsequent changes, perhaps that’s where the story about the discs going missing comes in?!
WMasterJedi
23 Nov 2023
England
I believe the Pic line announcements are not too dissimilar from these, I remember seeing TFL say that the system was by Whiteley Electronics well the PCBs which the 365 announcement EPROMs are on also say Whiteley Electronics.
Not only this but the visual internal PIS systems on both trains are very much alike, both are made by KeTech and both use the same dot matrix modules, not only this but the font that the dot matrix systems use is identical (same for the 95 and 96 stocks)
8 Apr 2010
Correct. And the system found on ADtranz/Bombardier 'Star' trains is a further development of this Whiteley system. At some point they switched from EPROM to PCMCIA cards, which is where the 73TS PCC file comes from. It is also evident from the 378 Overground announcements, that those trains were still using PCMCIA and BIN files. These import in much the same way as the 365 files, with distorted audio, but of course the original audio is also included in that case.
WMasterJedi
23 Nov 2023
England
I'm currently trying all sorts of sound conversion/editors to see if they not only support the format but provide a good result.
MrJeeves
28 Aug 2015
Burgess Hill
Indeed, this is what I'm having a play about with this evening. No luck so far, but I'm sure a breakthrough will happen.
Hats off to all you guys for the efforts on this, and for all that has been achieved so far.
If anyone had suggested a year ago that we’d have even a distorted version of the SE 365 announcements I’d have thought it was an April fool!
Seems like we’re so close now!
WMasterJedi
23 Nov 2023
England
I have tried all sorts of audio editors that can import ADPCM but they all yield the same result, best one being the Switch editor. (Which we have already heard)
365 Networker
19 Jul 2019
Something else that I just tried was changing the file extension to .RAW and then importing with NCH Switch. Interestingly, there was a slight improvement in voice quality, but the background noise still remains. So this still can't be the right format.
WMasterJedi
23 Nov 2023
England
I have been playing around with raw too, also used a couple things like ffmpeg and SoX.
365 Networker
19 Jul 2019
Do you think it would be possible to get these announcements working in Train Sim? I would love to be able to hear these whilst driving!
Also, I found a post from a while ago about the files for station announcements and converting them - could there be any similarities?
See post #49
WMasterJedi
23 Nov 2023
England
See post #49
I have tried using sox previously but it just results in a result slightly worse than what Switch provided.
365 Networker
19 Jul 2019
That’s a shame. I wonder if importing the files onto a virtual machine running perhaps windows 98 would have better results - from what I have seen online, windows used to have an ADPCM codec installed.
WMasterJedi
23 Nov 2023
England
View attachment GTNorthA.mp3
Best I could get using sox.
It's very clear and none of that clicking but the audio levels are bananas!
Converted into mp3 so I could upload it directly, final thing will be wav.
WMasterJedi
23 Nov 2023
England
I'm trying to use a program called dBpowerAMP, although an old version from 2004 as it supported raw audio data then.
Output is quite promising.
WMasterJedi
23 Nov 2023
England
In other amazing news, I now have every piece of the PIS system as I have just bought the full audible PIS controller unit!
I was able to get it £10 off by sending an offer!
365 Networker
19 Jul 2019
Presumably you can slot your EPROM boards into this? If so you would probably be able to get higher quality recordings of the announcements - there is probably a test mode which plays all of them.
WMasterJedi
23 Nov 2023
England
It already has EPROM boards in it!
The ones I already have were taken out of one of these, so this will have a board already in it!
365 Networker
19 Jul 2019
Something else of interest will be the audible chime for manual PA announcements - on certain units (I believe the ex WAGN units), the chime was slightly different. I'm also interested to see what can be accessed via the keypad.
