The same sort of electrical interference issues cropped up on GatEx services with 442s but NR were every quite able to definitively blame it on the 442s as there wasn't the required monitoring equipment in place.I wonder if the same leading unit has been involved in each COA.
I can envisage the 442 being withdawn from peak services services unless NR and fleet can solve the electrical interference issues.
Headways are already extremely tight London bound in the am peak, it's just not sustainable to have a train sit down for 5-10 mins while the issue is processed between driver and signaller essentially blocking the Up Fast.
The GatEx era issue is that the 3rd rail picks are on the end cars and the traction current return is all on the centre motor car and the return currents are much larger than other stock + a significant distance from the pick up that can cause problems for older type impedance bonds in certain locations especially near point work as the there can be a greater difference between return current through each rail through points and older impedance bond don't agree well with return current mismatches between running rails...
