Iskra
I'd pay good money for a decent print of this photo.
Agreed. Should be the new forum banner that.
May I ask what these modifications are?and the modifications to the guards panels and traction interlock system taking longer than normal.
Interlock mod is to prevent the train from taking power with a local door open (similar mods are also being carried out on the 455 fleet), it's also supposed to reduce the risk of 'roll backs' too.
The guards panels are being modified to make opening closing your local door a less of a 'faff', the panels (and the cab to crew handset) from the guards van are also being moved to a set of passenger doors in the motor coach.
he guard's van going then? And if so I'm assuming the slamdoors will be permanently locked. How's a local door a faff currently?
What are the downsides of leaving it in the sectional appendix?Most of the corrosion repairs were completed ages ago, delays are in part due to the company in charge of the internal refurbishment not being particularly well organised and the modifications to the guards panels and traction interlock system taking longer than normal.
In addition, half the problem is that the leasing companies (who are desperate to find use for older stock) will claim that modifications and commissioning will be simple and straight forward when from a practical point of a view its anything but, doesn't help that the TOCs will often use project managers with little experience in rolling stock either, so will usually take anything the leasing company will say at face value.
On top of that, GTR removed the 442s from the sectional appendix when they were withdrawn from GatEx duties, so NR are basically treating it as if a new train is being introduced to service.
They were still in the March 2018 Sectional Appendix (SA) for appropriate Southern routes that I have got downloaded, ie the public version. Also they were shown in the Wessex section for all the routes they would have previously used.What are the downsides of leaving it in the sectional appendix?
I appreciate doing this work maybe a good thing but is any of it being done solely because the rules state it must but actually it's otherwise not needed? I'm not say this is the case at all, just asking the question.They were still in the March 2018 Sectional Appendix (SA) for appropriate Southern routes that I have got downloaded, ie the public version. Also they were shown in the Wessex section for all the routes they would have previously used.
It was said earlier in the thread that they would they have to be revalidated for Wessex route, despite being shown in the SA. Which raises the question is there another way of preventing their use than amending them out of the SA.
An earlier poster wrote that Southern had significantly raised the unit’s ride height. That alone would mean revalidation surely?I appreciate doing this work maybe a good thing but is any of it being done solely because the rules state it must but actually it's otherwise not needed? I'm not say this is the case at all, just asking the question.
It would and I've not read every post on here so won't have seen that.An earlier poster wrote that Southern had significantly raised the unit’s ride height. That alone would mean revalidation surely?
Target date is from late February. However only the 3rd unit has just been done, internally.
So if they get a fourth one done fairly quickly, perhaps we could see two introductory ten car diagrams from the late of the month?Hi, is that internally and externally and all done and ready to roll??
Also, do you mean that is the 3rd 5-car ? If so, only 1.5 of the intended formation to run ready as they are supposed to only going to be run as 10-cars....?
2403, 2417 & 2420 are completed. 2406 is the 4th one to be done.
The livery is pretty much done on most of them now, just various finishing touches need to be applied. However, 2404 is still in plain grey.
Report in Jan Modern Railways says it will be done later in the year. There is a part (static converters) that is needed which wasn't originally planned for and it is taking a while to get hold of.What is happening with the retractioning? Has it just been quietly forgotten about?
All three still quite a long way from completed.
Cheers for that, had a feeling it was too good to be true!
One was in Wimbledon yesterday. Went up to the wheel lathe. Not sure of fleet number. Was tough to see from on top of the flyover
There's a return path in for tomorrow.2404 & 2411 still at WD at 15:20 today
