Class 442s - Now at the end of the road and to be withdrawn permanently
23 Nov 2015
Technically they could yes, but Siemens probably wouldn’t like it as the traction motors would be overworked. There has been cases of a unit hauling a dead unit but probably not advisable, especially on the gradients on the direct.
There'd be no auxiliary supply on the 350 either so it couldn’t be used for passengers. So a total non-starter.
Is there no bus between units through the Dellner?
No autocoupler has a large enough electrical connection for a bus line, even only for train heating purposes.
In any case, as the /1s have shoegear, fitting it to /2s is unlikely to be difficult or expensive (other than due to standard "railway inflation").
pompeyfan
24 Jan 2012
Ah right. Thanks for clarifying. There is an orange jumper socket at the front of the units though if I recall correctly? If they were to run as fixed sets could that work?
I completely agree however that it’s pie in the sky stuff, and if 350s were to be used on the PDL, then the most convenient way of doing to would be to add 3rd rail and fit them out in a comfortable 2+2 layout.
Had the 350/2s been available at the same time as the 442s, is the common feeling that FMTR would have preferred to stick with Desiros? Common sense would say so.
hwl
5 Feb 2012
No. the connection would need to support at least 3000A which is a very very chunk cable
None of the internal power cabling within any 4/5 car DC EMU power bus is built for that. (The 700 etc are build as seperate units to avoid some of these issues 2x4car or 2x6car).
Just have good look at all the cabling between the 350/450 cars
aleggatta
28 Sep 2015
What about the 313s? Didn't they have a 750V bus added?
I thought the Silverlink/LO ones did, in order to get the 508s to and from Willesden depot.
All 'original' 313s in use on GN don't have a 750v Bus line, so the 750v kit on each DMS will only take power from its local shoe gear. When transferred to SN a 750V bus was 'fitted' which I think ended up being some links fitted in the AC traction box on the PTS to create a DC bus line over the original feeder cables used when running on AC(Which were now redundant and all AC kit made obsolete). This also included the fitment of DC shore supply traction/auxiliary sockets, but none of this extends to the couplers or transfers between two separate multiple units. only the 'control' wiring is transferred over coupler electrical heads, which would have enabled a 'dead' unit to be dragged with full brake and traction control available from either open cab controlling whichever unit had traction power available.
K.o.R
6 Dec 2017
Saw what I think was 442408 in Fratton earlier, and it looked like they've replaced the headlamp clusters. Or at least the bulb; the reds were very clear and bright.
lsdghasu
20 Dec 2018
The 442s are being fitted with new LED headlights like on the 159s.
Wychwood93
25 Jan 2018
Burton. Dorset.
Mercifully we appear to be back on-thread! Quite where the drift to 350 units and the obvious ability they have to be closet 4TCs and coupled to 450/444 units came from is a mystery. From my viewpoint it will be good to have the 442s back - many, many miles under the belt with them - although not on the Direct from Pompey. I would like to be on the 1B94 1818 Poole to Waterloo on the 19th May, see what happens.
theironroad
21 Nov 2014
Does anyone know how many of the eighteen units have been refurbished?
That's the million dollar question which no-one seem to have an answer to.
Crunch time will be 19/5 and the new timetable when some will be needed if the publicised timetable enhancements are to be implemented.
pigs bay
29 Sep 2018
I have noticed on flickr that 2401 has been moved to what looks to be coupled to 2412, and on "wikipedia" it says that 2401,2405,2407,2412,2421,& 2424 are for spares. Please can anyone confirm this or is there still a glimmer of hope that they will all be back with SWR
pompeyfan
24 Jan 2012
I believe there are still 6 parked up in Eastleigh Arriva TMD, next to where the 800s are being stored.
Goldfish62
14 Feb 2010
Indeed. The Reading and Windsor lines alone appear to need an extra six units in the peaks.
I can see a lot of short formations come May.
doctorf5
26 Sep 2017
Just the 2 at Eastleigh Depot (2405 & 2424). The other 4 are at Ely.
Using them as spares might have been helpful early on, but not so much now 2 years later with suppliers in place.
RichSwitch
9 Mar 2017
Portsmouth
Probably commercially confidential, but does anyone know the actual mean spend-per-coach of refurbishing the 444/450 and the actual mean spend-per-coach of refurbishing the 442? Obviously one would expect the 442 to be greater spend than the Desiro because of all the additional work required to bring them up to scratch.
I’m guessing someone somewhere uses some kind of value-for-money or return-on-investment metric. Does anyone know for sure how long SWR intend to use the 442 before replacing them? I suppose my thinking is: are they a permanent solution or are they a stop-gap measure? Apologies if these questions have been asked before.
I posted the Figure for the 442 project earlier as intended to be £45M, (£500K per vehicle), as reported in Railway Gazette. It includes the retraction as well, currently deferred.
https://www.railforums.co.uk/thread...-and-redeployment.127422/page-98#post-3843566
The Desiros account for another £50M, (£68K per vehicle).
http://www.railtechnologymagazine.com/Rail-News/south-western-announces-50m-train-refurbishment
Another £15M is being spent on the DMUs, based on SWR announcing the all-in cost as £110M
_toommm_
8 Jul 2017
Per vehicle as in per coach, it per vehicle as in a full unit?
Vehicle = single carriage, as per normal railway usage of the word. Obviously an average, and because almost all of the 442 traction equipment is on the one centre vehicle, then work on that vehicle will be the vast majority of the cost per unit.
pompeyfan
24 Jan 2012
AC traction is ongoing with the first 2 units that are being converted in Eastleigh as it stands, they’ve been in there 6 weeks so far.
doctorf5
26 Sep 2017
When I went past a few weeks ago, the motor coach for 442402 was still outside at the back of the works, where it has been for months. I assume the rest of 442402 must still be at Bournemouth as only 442419 went back to Eastleigh in January (both units left Eastleigh without their motor coaches back in October).
Don Steedy
28 Jul 2018
You’d be surprised at how many parts are still causing major headaches. All the convertors and invertors off the 6 would be very useful for starters until the new convertors & invertors start to get fitted. The 1980s electronics did not enjoy their time being stored in a field in Cambridgeshire, and some are proving very costly to repair with some major internal components having to be specially manufactured in order to do so!
VEP3417
27 Jun 2011
Hampshire
my friend sent me this the other day, in a siding near portsmouth is all he told me, looks quite smart in the new livery
lxfe_mxtterz
3 Mar 2018
Sarahdale (West of Emmerdale)
Good afternoon all. :)
I have found some very interesting images of the refurbished interior of one of the South Western Railway Class 442s on Facebook.
Full credits to Grant Stallard on Facebook who uploaded these pictures:
I have attached a few of the images below.
