Islineclear3_1
What's an SRT ?
My thinking is that the AFK - VIC are more likely to be 465/466 after the December change, given the all stations Ashford to Maidstone service and the stopping pattern beyond Maidstone. Then again given the reductions on AFK services on the Mid Kent line and other services via the Medway Towns will the 11 377/5s left on Southeastern be able to cover VIC and CHX services to/from MDE.Basically yes. Kemsing, Barming, Hollingbourne, Harrietsham and Charing are all 6-car maximum without SDO. In theory an 8-car 465 set could use the line if on the semi-fast calling pattern, so I'd have thought an 8-car could be allocated to any of the MDE-CHX diagrams in the December timetable change, but I don't know what will be allocated where from December on that line, only that 375/377s will probably still form a large majority of diagrams.
No more likely than the current TT. Its one diagram that's only out in the peaks, the rest are 375/377My thinking is that the AFK - VIC are more likely to be 465/466 after the December change, given the all stations Ashford to Maidstone service and the stopping pattern beyond Maidstone. Then again given the reductions on AFK services on the Mid Kent line and other services via the Medway Towns will the 11 377/5s left on Southeastern be able to cover VIC and CHX services to/from MDE.
Could be 466001 and 033, which were seen going to Doncaster around a fortnight ago?Don’t know if here’s the place to put it, but 2x 466s are on 5Q88 Doncaster Works - Tonbridge Yard tonight. No clue what unit numbers as pitch black outside
Not really. There's an internal industry database called BPlan which has the full list, and data from this is extracted for use in planning systems. Bear in mind that there isn't always an SRT for every combination of pass/stop / pass/stop / start/pass / start/stop, nor between every timing point on the routes that a particular type of stock is cleared over.Are SRTs publicly available ?
Trust me, 2x66 double heading, 2 barrier wagons, 2x466, barrier wagon was the consistCould be 466001 and 033, which were seen going to Doncaster around a fortnight ago?
EDIT: If it's going to Tonbridge West Yard it can't be any passenger stock, as that's a freight yard.
They always stable overnight in Tonbridge West Yard before going to Slade Green the next day.Could be 466001 and 033, which were seen going to Doncaster around a fortnight ago?
That doesn't include updates between timetable periods though.BPLAN Geography - Open Rail Data Wiki
wiki.openraildata.com
Updated biannually and listed under the TLKs
Yes todays 17.39 Blackfriars to Ashford was 465/6.Apparently another 6 car set is diagrammed on this route on a short term basis that includes the afternoon Blackfriars' workings?
Yep. Monday to Friday only however:Yes todays 17.39 Blackfriars to Ashford was 465/6.
Will there be any after the December timetable change?
Are you sure it was 6 car? The live running info has it as an 8 car 465 466 466 formation there were a few short forms earlier so suspect it's likely to be a one off.Just saw a 6 car Networker formation shoot through St Mary Cray on what must be the 19:13 MDE-CHX, which is odd as I don't recall these diagrams having any scheduled 465/466s on them. Is this a one off or a new allocation?
I can double check when presumably it comes back into Maidstone East soon around 21:30. I don't have access to whatever live running info you're using, and it shot through non-stop while I was on the 19:25 from VIC-AFK (which also happened to be a Networker formation, but this is normal at the moment).Are you sure it was 6 car? The live running info has it as an 8 car 465 466 466 formation there were a few short forms earlier so suspect it's likely to be a one off.
The live running information is from Darwin which might be incorrect as 8-car seems very unusual. The feed data (which isn't shown on most websites) has it with 2 standard and 1 accessible toilet which doesn't fit with any electrostar formation I can think of.I can double check when presumably it comes back into Maidstone East soon around 21:30. I don't have access to whatever live running info you're using, and it shot through non-stop while I was on the 19:25 from VIC-AFK (which also happened to be a Networker formation, but this is normal at the moment).
I can confirm it was 465020 + 466012, so only 6-car. Interestingly the departure board reckoned the 22:13 to CHX would be an 8-car, even though only 6 are there, so that would presumably fit it being a last-minute swap.The live running information is from Darwin which might be incorrect as 8-car seems very unusual. The feed data (which isn't shown on most websites) has it with 2 standard and 1 accessible toilet which doesn't fit with any electrostar formation I can think of.
The Darwin data should be the same as the length displayed at the station (though as shown here doesn't mean it's right). It definitely looks like it's been reallocated, the 23:31 to Maidstone it goes on to form has 8 car length with an impossible 16 car formation half electrostar, half networker which suggests one got changed for the other and some system somewhere has got confused.I can confirm it was 465020 + 466012, so only 6-car. Interestingly the departure board reckoned the 22:13 to CHX would be an 8-car, even though only 6 are there, so that would presumably fit it being a last-minute swap.
I wonder if it's because late night engineering work is taking place between Ashford and Maidstone this week, meaning trains after 23:30 have to terminate in the bay platform, then to get to Ashford Down Sidings go the long way round, by running to Swanley, reversing, then through to Ashford via Otford, Sevenoaks and Tonbridge.The Darwin data should be the same as the length displayed at the station (though as shown here doesn't mean it's right). It definitely looks like it's been reallocated, the 23:31 to Maidstone it goes on to form has 8 car length with an impossible 16 car formation half electrostar, half networker which suggests one got changed for the other and some system somewhere has got confused.
Don’t know but from what I’ve seen it looks like any 465 will turn up. I’ve been travelling on the Charing Cross - Tunbridge Wells service recently and a lot of BRELs have turned up. So potentially they are just picking the units out of the general pool now.A question on this - now that there is no more First Class anywhere on SE, is any effort made to put 465/9s on these services or could it just be any old 465? It looks like the latter from observations this week (and conversely I’ve seen more /9s on the Orpington stoppers) but would be curious if this is just chance or is how things will be from now on. Would seem fair to try to keep the /9s on these longer journeys as the ambience is so much better
The 465/9s and other 465s are in two separate pools diagram wise. They can substitute for each other if required but there are intended formations. There has been a shift now there's no more first class to moving more 465/9 onto metro diagrams with most mainline services having just one 465/9. Metro diagrams have lower mileage in general which is probably the reason for the change.A question on this - now that there is no more First Class anywhere on SE, is any effort made to put 465/9s on these services or could it just be any old 465? It looks like the latter from observations this week (and conversely I’ve seen more /9s on the Orpington stoppers) but would be curious if this is just chance or is how things will be from now on. Would seem fair to try to keep the /9s on these longer journeys as the ambience is so much better
Mark 1 eyeballs show a fair few instances of 4/377 but not normally 4/375 passing Bearsted of a cross section of times during the day, all days a week.I see that a number of VIC-AFK services are now 4-cars, are these Networkers or Electrostars, or both?
The Maidstone - Charing Xs seem to be entirely 8/377 from what I've seen.That said, no idea now of course what they use on the Maidstone to Charing Cross trains. I assume it’s only 375s?
That surprises me, mostly on the basis that if they need to be taken by a spare man / woman to Grove Park or whatever to be got out of the way, I don't think Charing Cross / Grove Park / Slade Green / Dartford / Orpington (etc) sign for them, so could make it all a bit tricky. I'd have thought they'd have made a conscious effort to use 375s on them, and use the 377s only on stuff between Victoria and Ashford.The Maidstone - Charing Xs seem to be entirely 8/377 from what I've seen.
Seen as 377s work Victoria to Gillingham stoppers - I would assume they sign them!That surprises me, mostly on the basis that if they need to be taken by a spare man / woman to Grove Park or whatever to be got out of the way, I don't think Charing Cross / Grove Park / Slade Green / Dartford / Orpington (etc) sign for them, so could make it all a bit tricky. I'd have thought they'd have made a conscious effort to use 375s on them, and use the 377s only on stuff between Victoria and Ashford.
As an aside, do Gillingham depot still sign for 377s?
I remember Gillingham signing for them in the days of the FCC/SE joint Bedford to Rochester and Ashford services, but assumed they only really used them to Ashford now.Seen as 377s work Victoria to Gillingham stoppers - I would assume they sign them!
