Class 701 'Aventra' trains for South Western Railway: progress updates
Bigfoot
2 Dec 2013
A cynical reason may explain why the PIS do not show correct details on special or diverted services, is that the person's (guard or driver) union wants an extra payment for operating the system in this situation and the TOCs have said go away to the union. Therefore only the proactive member's of rail staff say sod the union, it is more important that the correct information is displayed and try to set the PIS correctly, but only a minority of staff think like that.
The pis functionality is part of the training course for the crew on a 701, so this is not the case here.
Ian Hardy
18 Nov 2009
Many thanks, I am glad that it is part of the course, hopefully the crews will put that training into practice so it becomes second nature to ensure that the correct information is displayed at all times.
TEW
16 May 2008
I'm sure all stock built after a certain date when PRM TSI superceded RVAR must be able to display the calling pattern and next stops for non-standard services and unscheduled diversions, so it will be a major issue if it's not addressed.
It is possible on 701s, but it isn't that simple. The PIS is usually fed directly from the headcode, but my understanding is that it takes the information from the standard LTP calling pattern for that headcode. The same input then sets up the GSMR radio.
There is a list of fake headcodes which will feed a complete route with all stops in to the system, and the driver can then edit it for the appropriate calling pattern, and will then have to set up the GSMR separately. I'm not sure how many drivers are going to do that. Ideally it's the kind of thing you would want the guard to be able to do, they'd be far more likely to take the time to do it as it makes their lives easier working the train if the PIS is set up correctly.
swtrains
30 May 2024
Today's testing (701013 & ???) - MULTIPLE TESTS TODAY:
5T91 - Clapham Yard - Waterloo - normal.
5T92 - Waterloo - Waterloo - goes to Kingston via Richmond, reverses, goes to Twickenham, reverses, goes to Shepperton, reverses and heads back to Waterloo via Richmond.
5T97 - Clapham Yard - Waterloo - goes to Waterloo, then goes to Epsom, reverses and heads back to Waterloo.
5T98 - Waterloo - Waterloo - goes to Chessington South, reverses, and heads back to Waterloo.
5T99 - Waterloo - Clapham Yard - goes to Guildford via Woking, reverses and heads back to the Yard via mainline.
Agreed, that's when it is most important. There's not really an excuse with "digital trains" - I can see different stopping patterns on an app on my phone, but the supposedly connected train is still rooted in 2005.
701 PIDs and announcements are crap in general because they cheaped out on it.
WWTownEnth
21 Mar 2014
Looks like this will be the next 701 diagram from Monday
No.11: 701 Diagram
Starts at Waterloo – 2H87 → 2H94 → 2R15 → 5Y87 → 5Y87 → 5V49 → 5V49 → 2V49 → 2H97 → 2H64 → 2H63 → 2H72 → 2H71 → 5H80 – Ends at Strawberry Hill Depot
Looks like it’s out and being operated by 701034…..
2 Jun 2023
Richmond
It’s just the standard one on all Aventras, so Bombardier cheaped out on it rather than SWR. However the software on the 701 PIS is particularly bad in comparison to others, so I’m hoping it’ll be updated soon along with additional info on the door screens.
DMckduck
26 Jul 2020
Ah yes, I had this one the other day where the guard was talking over the top of the automated annoucement, and it didn't mute the automated annoucement for some reason when the guard did his. The mic technique does vary between guard and it is obvious who does have the right technique and who doesn't. Does the tannoy system also have some sort of aggressive background noise cancelling/clipping, sometimes I have heard the guard has good mic technique but save for the occasional cut out?
Interestingly the 18:06 to Hampton Court from Waterloo was cancelled last night due to a train fault, does anyone know what the cause was? Nothing worse than riding a 455 in this heat, a wall of heat as you step on board the train.
Funny how the SWR guard microphone technique is only critiqued on 701s, manual announcements seem perfectly fine on all other stock?
It's obvious from the whole PIS system, how much funding was given for such an important system. Although to be fair the handsets are retrofitted as it was by design a DOO train.
Drivers simply aren't going to spend time focusing on editing the PIS outside of initial set up.
Whether it can be modified to hand over to the guard, would probably be useful if it could.
swr444
26 Aug 2008
It looks like 701025 will be the next one to enter passenger service
we'll see if it manages to run anything, the SWML has completely collapsed due to a points failure at wimbledon
Tirov
17 Jul 2014
23/6 013 017 025 031 034 035 036 037 039 041 042 044 046; 13 units against 11 last week!
The 0953 Tester did not run. 025 on the 1800 Waterloo Tester might run!
norbitonflyer
24 Mar 2020
SW London
Tester?
025 is shown on RTT as rostered for 2O53, the 1800 "Kingston roundabout" passenger service
NSEWonderer
5 Dec 2020
30 Jul 2015
Ah yes, I had overlooked that little detail that no Kingston loop services were going all the way round.
Unsurprisingly 701025 now de-allocated, so maybe tomorrow? It does not look like any of the afternoon ECS moves from Wimbledon Park ran with the last moves being the scrap train 5Q76 to Newport with 37800 hauling 5916 + 5912, and a 5X95 to Bournemouth which I am guessing was a 458/4?
NSEWonderer
5 Dec 2020
Yeah it most likely can't make it out, service is in a code black so potentially will be seen tomorrow.
mansonlo49
11 Dec 2023
uk
5Q76 seems some issues occurred, and now operating as 0Q76 with the scrap move stopped at Bristol Parkway
swr444
26 Aug 2008
Take two for 701025
FRSZMZ56
20 May 2025
SW London
NSEWonderer
5 Dec 2020
Take two for 701025
That completes the original trio of testing trains. Expected it to be next as both 35 and 44 had come into service and it had been part of that original trio of test units. Good to see!
2 Jun 2023
Richmond
Seems like they’ve removed the three loud beeps when the toilet is locked, at least on 701025. Positive change considering it’s a physical latch anyway so isn’t really needed.
NSEWonderer
5 Dec 2020
051 is out on 49 Track at Clapham Junction on driver training .
Might be faulty, ive always thought it was there for the visually impaired.
2 Jun 2023
Richmond
It’s not really required when there’s a latch, because it’s a physical lock. If it was a button, yes.
NSEWonderer
5 Dec 2020
It wouldn't be put on there if it wasn't required. Its definitely there for the purpose of an additional indication the door is locked. That being said then
