Chiltern006
- Joined
- 3 Oct 2018
- Messages
- 745
the more unreliable 465/2s will go first into storage.
Not entirely sure 465/2s as an entire subclass are any more or less reliable than any of the other subclasses (especially the identical 465/9s).the more unreliable 465/2s will go first into storage.
I wouldn’t be surprised if it was a mixture of /2s & /9s based on maintenance requirements given there are a lot of metro only 465/9 diagrams now that they don’t work anything on the Maidstone East Line and some of their Chatham Mainline work was cut back when the 377s came in. I think it’s a given that a number of 466s will go though, they’re the least PRM compliant and full of water! (Well most Met cams are thanks to the shoddy panel build quality from what became AnsaldoBreda).The case against the 465/2s is not very good, and only slightly better than the 466s. They're Angel owned (as are the 465/9s and 466s) so it requires no ROSCO cooperation to handle leasing arrangements, the brake pads need changing far more often than their /0 and /1 counterparts, and losing them wouldn't impact outer suburban routes like the loss of the 465/9s would.
707006 is out on test/driver training today - Currently working 5Q59 10+33 Grove Park C.S.D. to London Cannon Street: https://www.realtimetrains.co.uk/train/J32703/2021-03-23/detailed
I hadn't appreciated that the 377/5s had taken on some duties previously handled by 465/9s, but it makes sense.I wouldn’t be surprised if it was a mixture of /2s & /9s based on maintenance requirements given there are a lot of metro only 465/9 diagrams now that they don’t work anything on the Maidstone East Line and some of their Chatham Mainline work was cut back when the 377s came in. I think it’s a given that a number of 466s will go though, they’re the least PRM compliant and full of water! (Well most Met cams are thanks to the shoddy panel build quality from what became AnsaldoBreda).
That’s how it was explained in a few posts last Saturday, but it was unusually brought up in the general Real Time Trains discussion thread...SE were running over the flyover into Waterloo and shunting at queenstown road last week, might this have a link with Se drivers moving 707s as they are moved over?
It was testing emergency coupling procedures and went back to Grove Park afterwards.there being reliveried there so, you never know, but we may see a blue 707....
About 5 weeks till the first blue one appears.there being reliveried there so, you never know, but we may see a blue 707....
Driver training doesn't begin for a few months.Expect a ramping up of the training runs now.
Not for long...... and have now berthed at Grove Park CSD.
Emergency coupling procedures or are they going to provide extra capacity on HS1?It was testing emergency coupling procedures and went back to Grove Park afterwards.
Considering that there are parts of the Classic SE network that the Class 395s operate over eg Gravesend and the high probability that you will see Class 707s over the same parts of the network, I would say it's essential to ensure that emergency coupling procedures can be done.Emergency coupling procedures or are they going to provide extra capacity on HS1?![]()
None in the system currently.Anyone know if any tests are running tomorrow? Cheers
Maybe you're looking in the wrong placeNone in the system currently.
It only takes 2 units to carry out Driver training and SE has 4 with a other 2 due to arrive on the 3rd.Given how long it's likely to be before SWR release a significant proportion on the fleet I imagine there won't be any major driver training taking place just yet.
Thanks for the explanation.It only takes 2 units to carry out Driver training and SE has 4 with a other 2 due to arrive on the 3rd.
Driver training isn't due for a few months but that is because others are being trained first and service doesn't begin until... Drivers need to be trained as the units enter service so there is less of a gap between training and driving them.
Be interesting to see which depot the next arrivals go to on the 3rd, what with Grove Park being in the middle of a possessionIt only takes 2 units to carry out Driver training and SE has 4 with a other 2 due to arrive on the 3rd.
Do we know yet if there will be a net gain in carriages or if the number of Networker carriages leaving is equal to the number of 707s arriving? Given how stretched the whole SE fleet has been and Chart Leacon reopening works allowing some stabling capacity increase, having a net gain makes sense.I wouldn’t be surprised if it was a mixture of /2s & /9s based on maintenance requirements given there are a lot of metro only 465/9 diagrams now that they don’t work anything on the Maidstone East Line and some of their Chatham Mainline work was cut back when the 377s came in. I think it’s a given that a number of 466s will go though, they’re the least PRM compliant and full of water! (Well most Met cams are thanks to the shoddy panel build quality from what became AnsaldoBreda).
