Class 707 to Southeastern Dates
SE%Traveller
23 Jan 2020
interesting that the SE Twitter handler said they'd be working the Victoria Dartford Service, all stations west of Lewisham are are 8 car only as are Platforms
It’s not just the Twitter account, it’s also quite specific in the SE website news article linked in post #708.
That release doesn't mention Victoria
Yes sorry I meant Gravesend etc are definitely in scope. Are you thinking existing stock will have to remain on services to Victoria? SWR call 707s at plenty of short platforms, but they tend to be at the outer ends of routes.
CFRAIL
17 May 2019
There was a reply on Twitter that said they would be used from Victoria (as well as others)
Aictos
28 Apr 2009
The Siemens City Desiro family of which the Class 707s being to have selective door opening whereas the train will not open any door of the carriage if said carriage is not fully platformed so I can't see why platform restrictions on the London Victoria routes would mean that the Class 707s cannot operate out of London Victoria when SDO can be used.
I expect that’s what was being quoted in post #722 earlier… TOC Twitter feeds are not exactly renowned for their accuracy when covering longer term changes…
Rail.Fan
4 Nov 2015
Kent
I imagine the 707s are going to be used on all the services which the 376s use? Since they are both 10 car trains. Maybe they will be used a lot more on all the loop services allowing the ageing networkers to keep to shorter journeys?
DynamicSpirit
12 Apr 2012
SE London
There's the answer
Assuming by 'networker', SouthEastern mean the class 465's: According to wikipedia, SouthEastern have 147 of the 4-car class 465 Networker trains, (as well as 43 of the 2-car class 466's). They also have 36 5-car class 376s which are not as old and which - as far as I can interpret from the text you quoted - are presumably staying.
I'm not sure what the 30 5-car class 707s can do to replace any of that lot - the numbers of units don't seem to add up, unless it's simply adding some new units to increase capacity?
(Edited to fix class numbers)
Mikey C
11 Feb 2013
The Networkers have toilets, so surely would be on the longer services?
DA1
22 May 2017
England
Highly unlikely they would be on Vic services however they can go there as a 5 car if needed.
Doomotron
25 Jun 2018
Kent
I highly doubt it! Although I personally quite like the variety don't you?
I liked the period when the 375s were being repainted, but to be honest they've never been able to settle with one livery. Most of the Electrostars before being repainted were in Connex/SET livery, and the Networkers use one livery, but it was only applied to a handful of 375s. The Javelins came along with a completely new livery, and the 377s are still in First Capital Connect purple. And then there's the 376s...
Really, they should have stuck with the lilac livery used on the Networkers, because there would have been a bit more brand unity (and it looked stunning on the 375s).
Assuming by 'networker', SouthEastern mean the class 465's: According to wikipedia, SouthEastern have 147 of the 4-car class 165 Networker trains, (as well as 43 of the 2-car class 166's). They also have 36 5-car class 365s which are not as old and which - as far as I can interpret from the text you quoted - are presumably staying.
I'm not sure where you're getting 165, 166 and 365 from...
DynamicSpirit
12 Apr 2012
SE London
Thinking more about where the trains could be used... There are 30 units. Assuming they'll tend to be doubled up, that's 15 trains. I don't know what proportion of those would have to be undergoing maintenance at any one time, but I'm guessing, no more than 13 trains in service at any one time normally?
SouthEastern claim the 707s will run on the Dartford, Sevenoaks and Hayes lines. Quickly checking the timetable, it looks to me like you need 8 trains to run 4tph to Hayes, 4 trains to run 2tph to Sevenoaks, and 3 trains to run the 2tph to Orpington (if they count as the 'Sevenoaks' route). So if they were all going to be 707s, that's already more trains than are probably available - and I haven't yet even started counting the many more trains on the Dartford routes.
So I'm guessing we can rule out any route being given over entirely to 707s - which presumably means they'll just be mixed in with the existing units on various metro routes.
Oh sorry, that was a typo for 465, 466 and 376. Pretty bad typos lol. I'll fix my post.
I can't recall any concerns for Nunhead, Peckham Rye and Denmark Hill, but if a 10 car 707 ran the Orpington services, calling at Herne Hill in both directions and Brixton in the down direction would foul a prominent junction.
CFRAIL
17 May 2019
This is what SE have tweeted, certainly no Vic there (as expected)
DA1
22 May 2017
England
Looks like they've also ruled out (or forgotten) Gravesend, even though 376s occasionally serve there.
Wonder if the semi fast Gravesend services will be brought back with the Dartford stopper services being 707s.
Mikey C
11 Feb 2013
Well it makes sense that the longest services are operated with trains with toilets. I assume any 376 operation wasn't timetabled
43102EMR
28 Mar 2021
376 operations are most definitely timetabled for Gravesend.
Indeed they are - they’re interchangeable with the Networkers other than the Bromley shuttle and Mainline services.
They're not interchangeable on Victoria services I believe, or at least very limited in what they can do there.
BluePenguin
26 Sep 2016
Kent
I don’t understand what is meant by interchangeable and why are they not allowed to go to Victoria?
DynamicSpirit
12 Apr 2012
SE London
At a guess... because of platforms on that route only being long enough for 8 carriages? That 376's are 5 car-units and therefore need platforms long enough for 10 carriages (since you don't want to be running 5-car trains most of the time in that part of London)
urpert
1 Dec 2015
Essendine or between Étaples and Rang-du-Fliers
Correct. In 30 years of using that line I’ve had a 376 precisely once.
