Class 745 Stadler FLIRTs
Astro_Orbiter
8 Nov 2019
And they are getting twisted and bent into many many shapes. Ridiculous and unnecessary type of microphone.
Just the same as the now redundant stick microphones on the 317's, twisted and bent any which way just to get it tucked out the way lol
RealTrains07
28 Feb 2019
Is their a reason why the 745s dont have door close buttons?
Seems a bit odd considering the type of services they operate?
Rick1984
23 Aug 2012
No idea about a train radio. But at sea, on a VHF radio you turn the squelch down till the interference comes through, then slowly turn till it stops then give it little extra. As to what it actually is I haven't a clue!
delticdave
14 Apr 2017
Just the same with CB radio, if you wanted a private conversation on a busy channel but were reasonably close, you could adjust the squelch so it appeared to be private. It wasn't, of course. but you couldn't hear the other (angry) persons trying to use the folks trying use the same channel.....
trebor79
8 Mar 2018
I believe in those two cases, the squelch is adjusting the sensitivity to the received signal, filtering out the noise from the radio signal.
In the case of the 745 microphones, and squelch in an aviation intercom setting (which is why I'm used to), you're adjusting the noise filtering on the microphone input. Here you turn the squelch up until the intercom stops sending white noise into everybody's ears, then try speaking to make sure you haven't gone too far. When it's set right it will automatically transmit when you speak and then shut off when you stop speaking.
If you turn it up too far, your speech will chop in and out in a similar way to the announcements on these trains.
dk1
2 Oct 2009
East Anglia
Was so much less complicated making announcements via one for all handset on the desk.
py_megapixel
5 Nov 2018
Northern England
Just out of interest... is the talk back function (for communicating with the guard or responding to the passcom) also conducted via the stick microphone? Or is there a handset for that?
delticdave
14 Apr 2017
Thanks for the very helpful info, I never really understood how radios worked......... DC
dk1
2 Oct 2009
East Anglia
Its everything except GSMR which mercifully still has a trusty handset.
py_megapixel
5 Nov 2018
Northern England
Oh dear... does this mean that the audio from the passcom/guard's handset is just played through a speaker in the cab?
I don't understand why they wouldn't fit a handset, it can't be that much more expensive surely?
TitanMike
6 Aug 2018
The 2 745's being used on Stansted Express today are listed as train formations on journey check on the GA website.
dk1
2 Oct 2009
East Anglia
Was 103 & 106 but the latter later swapped with 108. Never know whether to put 745/1 stuff in this thread as it states Intercity.
delticdave
14 Apr 2017
Please do continue, the 745/1 will be used on the London - Norwich services anyway & they are not regional emus, just lacking 1st class seating. (& catering facilities, just in case someone needs to correct me........)
dk1
2 Oct 2009
East Anglia
Yeah its just it says Intercity and get picked up a lot on here for putting stuff in the wrong thread Haha. Also only seat back tables fitted.
Astro_Orbiter
8 Nov 2019
Perhaps the mods could remove the (Intercity trains) bit from the title? Or perhaps make a separate Stansted Express thread?
For the avoidance of doubt this thread is for the 745s of all flavours. The "intercity" moniker was added to provided a bit more clarity when the thread was first split and before they were in service :)
Pacerman99
23 Apr 2019
Third Rail Land
Does anyone have a seating plan or seating capacity numbers for the Stansted units? I gather there are more luggage racks/bike spaces than the intercity units.
Murray J
10 Aug 2019
East Grinstead
This pdf claims 722 (which I guess includes the 45 tip-up seats?) - but that was generated around order time, and specs might have changed:
according to the above link, the 745/1s have 767 seats, so presumably the 722 figure doesn't include the tip-up seats.
HowardGWR
30 Jan 2013
An article I read seemed to infer that the 745/1 would not have first class seats, as opposed to the 745/0. Does anyone know the breakdown between the two types, regarding first and second?
trebor79
8 Mar 2018
754/0 has 2 coaches of first class and 10 coaches of standard. Standard has a decent number of table bays and seat back tables on all other seats. There is a buffet bar between first and standard class.
745/1 is all standard class, with no table bays although there are seat back tables.
samuelmorris
18 Jul 2013
Brentwood, Essex
Early days yet but 745s are still averaging around 4000 MTIN vs around 50k-55k on the stock they replaced. 10 units for 9 diagrams will certainly be far too many based on current performance, once the timetable reverts to normal. I suspect it'll be a while before that happens, so hopefully between now and then the reliability will improve. No sign of improvement on the diesel units any time soon, we can only hope the electric only units will do better eventually.
py_megapixel
5 Nov 2018
Northern England
So if I'm understanding that right, they are failing almost 12× more often than what the replaced?
They'd better get saving for an extended lease on that LHCS then or they're not going to have a fleet large enough to run a proper service...
