Class 88 headlights
8 Mar 2015
Home Counties
Simple question - I was running through my photos this morning and I have a series of shots taken of 88010... but I noticed that for the pair of low-down lights, in some shots both are on, in another one neither is on, and on others, only one is one... all shots taken in a couple of seconds as it passed through... so question is - are they flashing lights, or do they flicker faster than the eye can see?
For reference, the light up top is on in all of them...
Domh245
6 Apr 2013
nowhere
Flickering faster than the eye can see, but caught by the digital camera.
driver9000
13 Jan 2008
That's the LED refresh rate being picked up by your camera.
50039
8 Mar 2015
Home Counties
Thanks - glad I’m not going mad! Haven’t noticed it on anything else - o
presumably the 68s are the same?
Is it a different type of light they use / different refresh rate?
hexagon789
2 Sep 2016
A number of trains with LED lights but the refresh rate on 68/88s seems to be such that it's more noticeable than elsewhere
fgwrich
15 Apr 2009
Hampshire
The new "bugeye" LED Lights fitted to Great Western's Turbo fleet (and some 66s) also do the same. It's less noticeable on standard cameras (like mobile phones) but very noticeable on higher end and CCTV cameras.
rebmcr
15 Nov 2011
St Neots
LED road traffic lights and LED pedestrian crossings do it too.
superjohn
11 Mar 2011
Does this allow the lights to illuminate at variable brightness? For example, the same lamp used for day and night headlights.
TRAX
2 Dec 2015
France
Yes I believe these locos have that feature, although it doesn’t have anything to do with the effect LEDs have on cameras.
pompeyfan
24 Jan 2012
The same thing happens when people try to photograph LED destination blinds. I’ve never understood the science behind LEDs flicking.
hexagon789
2 Sep 2016
Something to do with the pulse rate of the LEDs compared to the frame rate of a camera when you take a picture.
route:oxford
1 Nov 2008
Technically a standard domestic filament bulb flickers 50 times a second too. It's just that the filament takes longer than 1/50th of a second to cool that you never notice.
John Webb
5 Jun 2010
St Albans
The brightness of LED lights can be varied by using 'Pulse-width modulation'. An LED at full brightness has a constant voltage across it. By providing pulses of full voltage at a sufficiently high frequency, the average light output from the LED can be reduced as seen by the human eyes due to the 'persistence of vision' that the human eye has. This is done by varying the length of the On time to the Off time.
Destination blinds and platform displays contain large numbers of LEDs. To connect each one to a separate circuit would lead to a huge number of connections. The LEDs are therefore arranged in a grid of horizontal and vertical connections. Driver circuitry converts the required information into which LEDs should be on and off, and rapidly scans the vertical and horizontal connections and turns the individual LEDs on as required by energising the appropriate horizontal and vertical connection. By doing this at high speed the human eye again perceives a steady light but cameras, both still and video, see the scene without 'persistence of vision' and will catch the LEDs off when the human eye thinks they're on!
Hope this helps,
malc-c
1 Dec 2017
Yes, pulse width modulation and multiplexing at work, captured by the camera's shutter speed. Not my video, but this is a good example
jh64
3 Sep 2015
A similar camera 'trick' can be seen with helicopter blades, if the framerate and the rotor blade rotation manage to line up right:
xotGD
4 Feb 2017
I've taken videos of 68s with the same blinking light effects. Physics is interesting!
furnessvale
14 Jul 2015
That's why factory lighting runs (or did do when I was a lad) off different phases so that rotating machinery doesn't look stationary at certain revolutions.
15 Apr 2020
Wakefield
Refresh rates are still taken into account with lighting regarding machinery etc yep, it’s in the regulations.
And it’s why so much planning goes into TV and film lighting/cameras to make sure the various refresh rates of cameras and all lights are synced or so fast that it’s not noticeable. Super slow mo replays in sports often really look flickery because of this effect.
50039
8 Mar 2015
Home Counties
Thanks folks - really interesting stuff... never noticed before, not on any of the 66s I’ve photographed..
Peter Sarf
Croydon
If the rotation is at the right speed in relation to the frame rate a wheel or rotor blades can even appear to be going backwards !. Can see this with the naked eye if the lighting is flickering at the right speed I believe.
What did puzzle me is that the OP said the top light appeared to always be on. Is that then an incandescent bulb maybe ?.
Domh245
6 Apr 2013
nowhere
It looks like it's also LED, but If I remember rightly because it is a marker lamp (as opposed to a head lamp) it only has one brightness, so doesn't need to be driven by PWM and can instead just be normal DC, avoiding the flicker
