Police refused to rule out criminal charges as sources suggested the crash had likely been caused by a signalling problem
www.telegraph.co.uk
Salisbury train crash may have been caused by signalling problem
Police on Monday night refused to rule out criminal charges as sources suggested the crash had likely been caused by a signalling problem.
...Network Rail initially suggested the first train had hit an object, causing it to derail and knocking out signalling in the area, before the second train ploughed into the stranded service.
But British Transport Police later said "at this early stage, there was nothing to suggest" the train had struck an object before derailing.
A source at Network Rail said the working assumption was a “multiple” failure in signalling allowing both trains into the tunnel at the same time.
The source said the trains should have been kept apart by a signalling block system with the second driver held back by a warning signal.
But even if the driver had missed the signal, the trains are fitted with an automatic Train Protection and Warning System (TPWS) that should have put the brakes on within seconds.
“It looks like something technical has gone wrong here,” the source said.......
