Maybe it’s important to point out that a modern colour light signal, that can only show red/green, can precede another signal with a red/(yellow)/(green) aspect under certain circumstances. It depends on which signals are protecting the block section (be it track circuit block or any other type). The block section limits (plus other details) are used to form the aspect sequence diagram.
For example, prior to the re-control of the Westerleigh to Swindon line from Bristol Panel to TVSC, signal UB103 at Chipping Sodbury tunnel was not a section signal. It was in the middle of the axle counter section. It normally showed green regardless of where trains were. The controlled signals in rear B119 (up Badminton) and B417 (goods loop) hence although three aspect colour light heads, had their middle (yellow) aspects blanked out (one had a metal plate painted black, I can’t remember what the other one had). The signal ahead (beyond) UB103 was UB99R (a two aspect colour light repeater, with yellow and green aspects), followed by UB99 (three aspect colour light).
Hence the block section was between B119/B417 and UB99 signals. UB103 was retained after axle counters were installed (previously track circuitsso that if the tell tale wire was broken or the signaller operated the Chipping Sodbury tunnel emergency switch, it would show a red aspect.
A different situation can arise on branch lines where the service level is low. In order to keep costs low or for other operational reasons, including minimum alterations due to layout changes or changed requirements. For example signals may be required to be provided, complete with red/green aspects, but which are not treated as section block signals. The line between Avonmouth station and Severn Beach is an example.
Trains travelling from Avonmouth station towards Hallen Marsh junction encounter SA7 signal (provided with red and green aspects) then SA47 (red/green aspects). SA47 protects the points at Holemouth junction. If SA47 is routed to Severn Beach, this is the last main aspect colour light signal. Leaving aside the special GPL SA627 (which normally shows two white lights), there is a fixed distance board on approach to Severn Beach station and the stop blocks. But if SA47 is routed over to the Up Avonmouth Dock line towards Filton West, SA47 signal requires SA37 signal to be showing a proceed aspect before it will clear. SA7 signal in turn requires that SA47 is showing a green aspect...
Here, SA7 is the block section signal. The line between SA47 and Severn Beach being a One Train Working (OTW) section). For the route to the Up Avonmouth Dock line, SA37 is the next block section signal.
