In the UK, it seems that concrete (or steel) are synonymous with welded rail, yet in most of the rest of Europe sleepers are still largely wood.
Why is this?
Why is this?
No idea, the French invented them I believe. I've never noticed greater use of wooden sleepers on the continent, and certainly as per Britain, France and Germany use only concrete on higher speed lines.In the UK, it seems that concrete (or steel) are synonymous with welded rail, yet in most of the rest of Europe sleepers are still largely wood.
Why is this?
Don't know if there are any British installations, but New Zealand uses themAre recycled plastic sleepers used all that much?
Reckon you're right. Anywhere else in the UK?Ffestiniog I think.
RailAdvent said:The Ffestiniog Railway has announced that it is replacing the wooden sleepers with brand new plastic ones.
Recycled mile bottles make up most of the plastic used in the new sleepers, which look very similar to the wooden ones, the differences only become apparent when you are close to them.
Why is this?
the Settle-Carlisle was changed from steel to concrete because of issues with the steel sleepers.
A few years ago (maybe as much as 10, I can't remember) there was a Network Rail press release about using recycled plastic sleepers. I contacted them for some further information (where are they being installed?) but never had a reply. The presence of a press release suggests they exist somewhere on the main line.Don't know if there are any British installations, but New Zealand uses them
Yes, this is true and small groups of wooden sleepers - usually about four at a time - are often used between station platforms, where they can be shortened to accommodate drainage catchpits between the lines. Obviously it's not possible to saw a few inches off the end of a concrete sleeper.I seem to remember I read somewhere that wooden sleepers are used over some bridges as they act as damper to some dynamic loads into the bridge structure. Does anyone know if this is true?
It is actually possible to cut down a concrete sleeper. I think the saw was called a dura-blade; NR weren’t overly keen on it as the newly exposed end should be sealed, and there was a risk that exposing the reinforcement would lead it corrode quickly.Yes, this is true and small groups of wooden sleepers - usually about four at a time - are often used between station platforms, where they can be shortened to accommodate drainage catchpits between the lines. Obviously it's not possible to saw a few inches off the end of a concrete sleeper.
IIRC, Airdrie to Bathgate was built using (machine laid) steel sleepers. That’s 85mph and in normal times, 4TPH, albeit 6 car EMUs & not freight. Whether they’d be used on a similar installation today is a different question.Steel sleepers are (were) laid in areas where there was low traffic, not high speeds,
Liverpool Street I believe has wooden sleepers because it was easier to install in the space and possession time available even though it has a shorter lifespan than concrete.
Perhaps as an experimentA few years ago (maybe as much as 10, I can't remember) there was a Network Rail press release about using recycled plastic sleepers. I contacted them for some further information (where are they being installed?) but never had a reply. The presence of a press release suggests they exist somewhere on the main line.
Yes, and where the ballast needs to be shallower for certain reasons it's also done sometimesLiverpool Street I believe has wooden sleepers because it was easier to install in the space and possession time available even though it has a shorter lifespan than concrete.
In Rail issue 923 (current issue), page36 there’s an article on the flat crossing at Newark and describes the bearers as ‘fibre-reinforced foamed urethane’ (FFU).Reckon you're right. Anywhere else in the UK?
Ffestiniog Railway use milk bottles for new rail sleepers
The Ffestiniog Railway has announced that it is replacing the wooden sleepers with brand new plastic ones.www.railadvent.co.uk
Extract of story...
I’m sure I read an article in the PWI (Permanent Way Institute for those who don’t know) magazine that Newark flat crossing was relaid in plastic bearers. They had to have them spray painted brown, as otherwise they’d have been white when installed!
Hardwood bearers are used on some bridge structures simply because the bridge was only designed for that type. It’s not practical to use concrete and the cost of a custom design of steel sleepers is likely too expensive.
British Railways has used reinforced concrete bearers for plain line for many, many years. I don’t know for how long, but Western Region had a big push on this during the 1970s. Network Rail now uses reinforced concrete bearers for switches (points) and crossings and has done for years. But only for new junctions or when junctions are being relaid.
Steel bearers are not liked, and may have fallen out of fashion. Because they cannot be manually packed (they are like upturned horse troughs, if you jack them up, all the ballast falls out). So the only option is to machine tamp lines that have them. You will however find them on branch lines, freight lines and in places, even on main lines.
Hardwood bearers are still being installed on Network Rail lines, but only to replace rotten existing bearers. Mostly on branch, freight lines or other low speed, low traffic areas. Especially where it is difficult to justify the cost of relaying using concrete bearers.
And there are still lots and lots of switches (points) and crossings which use hardwood bearers, simply because you are not supposed to mix and match concrete with wood on the same S&C. So until the junction is relaid, it will stay wood.
Any idea as to the current cost of a fully fitted Fastclip Steel Sleeper?
And a G44 Fastclip?
The short answer is - it isn't.In the UK, it seems that concrete (or steel) are synonymous with welded rail, yet in most of the rest of Europe sleepers are still largely wood.
Why is this?
