markymark2000
Not sure if this belongs in speculative or the London Underground area so I will put it here and if needed, I'm sure Mods will move it.
This idea comes following what has been said in the 'will the waterloo & city line ever reopen' thread (https://www.railforums.co.uk/threads/will-the-waterloo-city-line-ever-reopen.208426/page-2)
Basically it has been mentioned that the flow of commuters who normally use the W&C line just isnt there but my question is is the line was adapted to accommodate DLR trains, the service could then run all day, everyday and more people would likely use the service as there would be more through destinations. It would also help for if anything happens on the Jubilee Line as then the DLR will link the Docklands to Waterloo. I think that on top of this, I believe that the DLR taking over this area would make operational costs lower as you wouldn't need dedicated maintenance nor dedicated office staff for the W&C line, all maintenance and operational stuff will be done from existing DLR bases. All of this creates a cheaper network to run. It's worth pointing out as well that the W&C drivers 'step back' at Bank in the peak times. This would be completely removed as the DLR would go 'through' Bank and at Waterloo when they go into the sidings, staff can move about then if they wish to or stay where they are as they don't need to be in a certain place.
Pros:
Operational cost savings
Some improved links for people around Shadwell/Limehouse/Westferry DLR stations
Potential for a more consistent service without the huge operational cost (IE extending service hours by 1 hour would be minimal on a DLR extension compared to running the W&C).
Backup for if anything goes slightly wrong on the Jubilee Line.
Will help people with journey planning since there will be 1 less line on the map.
Depending on which services run to Waterloo, there is potential for direct links from Waterloo to City Airport or the Excel (possibly none but that would be a TFL decision)
Cons:
Potentially having to relocate the DLR to Monument station.
The cost of amending the current tunnels and infrastructure to accommodate DLR trains
Potentially confuse a few people if the current part time service remains as passengers may get used to services running to the same place at all times.
Pros:
Cons:
