Couple of questions regarding m-tickets from GWR
ngood77
30 Nov 2012
Hi all,
A couple of generic questions for you...
1) I’ve booked a journey using about 4 different TOCs. All tickets for the journey were offered to me via the GWR app, rather than Collect at Station. It’s safe to assume that because I have the tickets in the app that all TOCs involved, their ticket gates, and on board inspectors, will be able to scan the app tickets ?
2) I’ve a couple of legs that are Off Peak tickets. But the ticket description says break of journey is not permitted. I thought that all Off Peak journeys could be broken, but is that not actually the case ?
Thanks,
Nick.
island
30 Dec 2010
If the tickets have been issued to you as e-tickets, they should (TM) work throughout.
Some off-peak single tickets and the outbound portion of some off-peak return tickets do not permit break of journey. To confirm whether or not this applies to you we would need to know the origin and destination of the tickets. The enforceability of break of journey tickets is a subject of frequent debate and little consensus on the forum, but it mostly arises only at Preston and Crewe.
... will be able to scan the app tickets ?
No you cannot guarantee this; it's very possible they won't have scanners, depending on the TOCs involved. But equally it's not your problem!
I'm curious though; your post reads to me to suggest you were offered a combination of tickets for your journey; I didn't think GWR did that.
The general principle is that break of journey is allowed on all cases in the return portion, and also allowed on the outward portion unless the ticket specifically prohibits it.
Are these m-tickets by any chance? I would absolutely avoid any tickets issued in this format which may be tied to a specific app and/or come with more onerous apparent restrictions than should be the case.
If you can post the details of your journey/tickets (perhaps from the booking confirmation) we would be in a position to give accurate and comprehensive advice :)
ngood77
30 Nov 2012
Hi chaps,
Thanks for your replies.
I’ve checked the stopping points of the off peak legs, and there aren’t actually any intermediate stations to break at. So maybe that’s why the restrictions say a break is not permitted ?
I bought four separate journeys in one transaction via the GWR website, and all four journeys (making up my one overall trip - I used split ticketing) are in their app, waiting to be scanned, or not !
Hi chaps,
That's not the reason, no.
Without knowing more information, it's not possible to give a comprehensive answer.
It sounds to me like you have m-tickets, which in future I would recommend avoiding.
For example I recently made a journey using multiple e-tickets for one journey; if I had an issue with my phone I would have still been able to show the e-tickets (I could have printed them or shown them on another device); it was also really easy to show the combination to staff as all e-tickets were in one PDF so it was simply a case of scrolling down for each ticket; it was really easy to claim Delay Repay within seconds as I simply attached one PDF file which covered the entire journey. I was also able to select a specific seat using an online seat selector. I also held an easy to follow official itinerary which showed all trains being used for the journey, which I would have been able to show in the event of any issues such as missed connections.
m-tickets bought through the GWR app would have none of those advantages, and also have numerous drawbacks as your rights can be reduced/eroded.
ngood77
30 Nov 2012
Fair enough, I guess it’s down to personal preferences. The things you describe aren’t advantages to me - I like everything to be on my phone if possible, and not to faff around with carrying bits of paper. The app gives me all of the itinerary info, and it seemed to work fine when I used it last week.
As somebody mentioned above if a TOC can’t scan the app then that’s their problem not mine, I’ll just be waved through.
The break of journey question is academic now that there are no breaks possible anyway, so thanks again everybody, this one can be closed.
Enjoy your weekends.
I have the same preferences but I think you misunderstand what I wrote e-tickets don't have to be printed (but they could be if you wanted them to be, e.g. if you lost your phone)
I also don't want to faff with paper, nor do I want to be tied to one app on one device, which may be lost or stolen.
I find e-tickets where all tickets are on one PDF to be the easiest, as you can show a huge string of tickets within seconds as it's all in the same document.
Interesting. I didn't think the GWR app would give you a through itinerary for the journey in conjunction with multiple tickets; is this a new development?
Unless the app itself stops working, or the device is lost/stolen.
It is likely that the only reason you are barred from breaking your journey is because you have been issued m-tickets, but glad to hear it doesn't affect you on this occasion.
I understand you are happy with m-tickets, and don't mind the break of journey restriction that has been (incorrectly) applied to that medium, and that is entirely your choice, but others will be reading this thread and I feel I have a duty to point out the problems that can occur with this medium, so here are some examples of actual problems which people have experienced.
If the app fails to work correctly through no fault of your own, some companies will (unlawfully, in my opinion) ask you to pay again:
https://twitter.com/northernassist/status/1215222631349346304
Northern Rail said:
Hi, you will need to explain to the conductor what is happening, if you cannot show a ticket you may have to purchase one from the conductor and claim a refund for the app ticket. ^IB
@Ella_maexx said:
shouldn't have to though when it is clearly a fault with the app. What is the recommended course of action if she doesn't have enough money to purchase a second ticket?
https://twitter.com/george79544022/status/1147886805049577472
GWR said:
your app is still down and your staff still don’t know what’s happening. Woman’s at the gates at Swansea telling me it’s been fixed and I’ll get charged for a new ticket when I’m literally showing her the error live
You may also be told to unexpectedly delete and re-install the app, even where the company knows the app is at fault:
https://twitter.com/620721steve/status/1225042676468371457
GWR said:
Thank you, sorry to hear this. Have you tried deleting and re-installing the app at all? - Michaela
Stephen Harber said:
Why are you telling her to do this when you know you have a issue with your app. You have been tweeting about fault all morning
Resetting your phone with e-tickets is no problem but with m-tickets it can be a headache:
https://twitter.com/louisa_3996/status/1218097768721461248
louisa_3996' said:
so i had to reset my phone and your app uninstalled with my tickets on it, now i cant redownload them because "Barcode is downloaded on another device". its not another device, its the same. I cant access any of my tickets, is there any way you can help?
This customer 'updated' their phone and was told the Train Manager 'may' let them travel but the customer was entirely at the mercy of the train manager and the customer had to agree to make a telephone call at 0800 while on the train in the presence of the Train Manager (the train departed at 0735) who may or may not allow travel:
https://twitter.com/umarfarrukh/status/1096654255786811393
umarfarrukh said:
M ticket was downloaded on the phone, phone was then updated and now the app says "ticket barcode already downloaded to another device", went to virgin staff they couldn't resolve
Virgin said:
If you speak to the Train Manager they may allow you to travel if you can call the support team onboard when they open to resend the ticket but can't say for sure as it's down to the Train Manager ^SB
Many of the above examples are breaches of contract and consumer laws, but that won't stop train companies pulling a fast one. Not only that, but if you stand by your contractual rights, they might threaten you with criminal prosecution under archaic laws.
GWR's "e-tickets" are e-tickets, they just aren't delivered by e-mail for some bizarre reason. They don't require activation and look like e-tickets. They just don't get sent as a PDF in addition to the app. They aren't however m-tickets - a requirement for activation is a key identifier for these.
I just don't get why this is not standardised.
CrispyUK
19 Jan 2019
Can they be printed from the app?
No (though I doubt anything stops you screenshotting one).
They are a bizarre thing and I don't get the point of them. You can purchase proper e-tickets on the same flows using another app e.g. Trainline.
They are definitely not m-tickets, though, as activation is not required.
CrispyUK
19 Jan 2019
Sounds like they are somewhere between an e-ticket and a m-ticket (an i-ticket perhaps? 8-))
Agree with your earlier comment that the format should be standardised!
