Couple Trainee Driver Questions.
bcfc171081
27 Apr 2021
Taunton
I see most answers to individual thread are read the sticky thread. But just a quick one. Looking to change career from HGV driver to train driver.
I notice on some they require GCSEs A-C and others they don’t mention it. I only have Ds but I do have NVQ level 3 from my collage days. Is it worth me even applying? Or do the test you = C level.
also I’m from Taunton (5 mins from the station) is it worth applying to others. Is the must live within 1 hour mean to drive or public transport.
thanks in advance
ps, I know Theses are irrelevant until a trainee position actually comes up.
DanDanPlym
26 Nov 2019
Plymouth
I looked into this recently as only got a D at GCSE maths. Got good grades in all other subjects but just missing my maths.
I’ve retaken my Maths and got an equivalent B in a functional skills course which is recognised by nearly all employers these days.
It’s one of the reasons they’ve changed the marking system to a numerical scale 9-1.
Regarding your NVQ3, it will need to be relevant to the qualification stipulated by the TOC. I.e., you’d need an NVQ3 in maths say, for it to be applicable to your application. They won’t accept just any old NVQ3 as an equivalent qualification.
If you haven’t got an equivalent qualification in Maths / English, which is what most TOCs are looking for, then you’ll need to consider retakes in GCSE or a functional skills course via Learn Direct or similar
Good luck
L401CJF
16 Oct 2019
Wirral
I think a lot of TOCs are switching from "Trainee" jobs to "Apprentice" driver jobs. Which as far as i know is basically the same only I believe they receive funding from the government (??), and have an option to do the functional skills - English maths IT etc as part of the course for those who don't hold suitable qualifications already.
Sure someone else could clarify!
bcfc171081
27 Apr 2021
Taunton
Good luck
Thanks for quick reply, I will certainly look into that.
DriverEight
18 Feb 2021
Sunderland
thanks in advance
The travel time to the depot are for cars usually. Due to the start and finish times, they often ask you how you would get to work without using public transport, so if you don't drive put 'taxi'
bcfc171081
27 Apr 2021
Taunton
Hi, thanks for reply. Yes I do drive. Ok that opens up where I can apply a little. Think Bristol would be pushing it a bit but certainly Exeter the other would be ok.
TheGoldfish
28 May 2019
This is correct from my understanding although I don’t think it’s an option as such ... if you cannot produce the evidence they require of your qualifications .then you’ll have to do the functional skills stuff
L401CJF
16 Oct 2019
Wirral
That's what I meant, thanks for clarifying
S-Car-Go
19 Mar 2019
For some TOCs, and taken from experience in my training, the functional skills (maths, English, ICT) are compulsory as part of the apprenticeship programme. If you have the equivalent GCSEs A-C certificates in those subjects, you are exempt from that part of the course.
