Class800
via London or via Birmingham? What do you think? Bit short of time, but hopefully clear - looking for which route is best
Going via Birmingham is likely to be a whole lot more expensive than going via London. The cheapest through fares are via Kensington Olympia avoiding both.via London or via Birmingham? What do you think? Bit short of time, but hopefully clear - looking for which route is best
Yes, the routeing of the ticket is via Clapham Junction but not via London which means the West London Line.OK thanks - and timewise I'd expect it's sort of similar. Via Kensington, what would be the routing there, have to go via Clapham and the west London line?
Could you define "best" for us?looking for which route is best
possibly depending on what time the departure is from Cranbrook if on a weekday. I think for stations before Honiton (but not including Honiton) it was valid on the 08:2x from Exeter St Davids, but I cannot recall if Cranbrook was added to the list of easements when it openedIf you use SWR from Cranbrook into Waterloo then you can use your Network Railcard throughout.
Follow the link from https://www.network-railcard.co.uk/about-the-railcard/using-your-railcard/:possibly depending on what time the departure is from Cranbrook if on a weekday. I think for stations before Honiton (but not including Honiton) it was valid on the 08:2x from Exeter St Davids, but I cannot recall if Cranbrook was added to the list of easements when it opened
Cranbrook 08:37 09:40 South Western Railway service to London Waterloo
To all destinations
