Sad Sprinter
More electric freight might be able to get up the hills faster, possibly. Might get an extra path out of that.
Co-Co as well
From St Pancras via the Erewash (I assume?) or KX - Retford?It's firmly in the what-if territory, but I find the idea of an interworked Midland Cross-Country service with a hub at Derby quite interesting. You'd have 4tph on each of the London, Leeds, Manchester and Birmingham legs divided between the various routes:
- 2tph London-Nottingham, avoiding Derby entirely
- 2tph London-Manchester via Derby & the Bakewell route
- 2tph London-Leeds via Sheffield
It brings quite a bit to the party - potentially faster Sheffields and massive capacity/connectivity enhancements E Midlands - Manchester. And we could stop one of the Sheffieds at Alfteton to boot.I'm not sure it brings an awful lot to the party compared to the service we actually have, but it's fun to imagine!
- 2tph Leeds-Birmingham
- 1tph to Oxford & Southampton
- 1tph to Bristol, Exeter & Plymouth
- 2tph Manchester-Birmingham
With a "hub at Derby" I'd assume it means extending the existing St Pancras to Sheffield service.From St Pancras via the Erewash (I assume?) or KX - Retford?
Apart from the slight problem of finding cash to re-open the Peak Forest route, this would put six EMR long-distance expresses into St Pancras, plus the Corbies. Would that not cause a problem too?
Almost certainly. To be honest the assumption is that the Peak Forest route remains open and St Pancras isn't chopped up between the MML, Kent, and Channel Tunnel services. Firmly pie in the sky, in other words!Apart from the slight problem of finding cash to re-open the Peak Forest route, this would put six EMR long-distance expresses into St Pancras, plus the Corbies. Would that not cause a problem too?
Yep, the East Midlands to Manchester service is what really makes or breaks it. My assumption is that it comes at the expense of Birmingham-Stoke-Manchester on the CrossCountry network, but that can probably be done with EMUs similarly to Birmingham-Crewe-Liverpool.It brings quite a bit to the party - potentially faster Sheffields and massive capacity/connectivity enhancements E Midlands - Manchester.
Exactly so - it's really an London-Sheffield and a Leeds-East Midlands service that combine.With a "hub at Derby" I'd assume it means extending the existing St Pancras to Sheffield service.
Wouldn't really compete with the ECML for London, but I don't know how easy it is to do Leicester or Kettering to Sheffield - or how many people would want to.
Would single-tracking through the tunnels as done between Tunbridge Wells and Hastings solve most of the problem, leaving only the over-bridges?Good luck clearing the Settle and Carlisle for W10 clearance.
You could probably do a load of track lowers, but the real issue would be the cost of doing so.Would single-tracking through the tunnels as done between Tunbridge Wells and Hastings solve most of the problem, leaving only the over-bridges?
The Glasgow-West Yorkshire route still exists and could be recreated - I suggested an indicative timetable on the speculative S&C thread at https://www.railforums.co.uk/thread...m-and-ribble-valley-lines.235399/post-7265579Glasgow-West Yorkshire & East Midlands ought to be a decent flow but is weirdly underserved.
Which is why single-tracking the tunnels would be cheaper.You could probably do a load of track lowers, but the real issue would be the cost of doing so.
The only direct trains between the second and third largest cities in the country? That ought to be a priority to keep.My assumption is that it comes at the expense of Birmingham-Stoke-Manchester on the CrossCountry network
I still have them, they just go via Derby. The principle of the thought experiment was 'What would the Midland Railway do with modern resources?', which is why it doesn't particularly consider the WCML.The only direct trains between the second and third largest cities in the country? That ought to be a priority to keep.
And all the ancillary signalling, reduction in overall capacity etc.Would single-tracking through the tunnels as done between Tunbridge Wells and Hastings solve most of the problem, leaving only the over-bridges?
Yes, but would the route now be viable for trains carrying the largest containers? Only after that point is established should consideration be given to possible consequential problems. The number of inter-model trains per hour running between Weaver Junction and Carlisle is not enormous so diverting them would not add huge numbers to a very lightly used route originally built as a main line.And all the ancillary signalling, reduction in overall capacity etc.
No, you look at the consequences and requirements as a whole. Just becuase it was a main line 60 years ago doesn't mean anything. You don't do something and then say "ah, that bit doesn't work now, what do we do?" and then wait another 5 years before you can fix it. Do these diverted trains work across the WCML at Farington, Blackburn, Daisyfield, through the long block at Clitheroe and across the job at Carlisle, what impact is there to the journey time, what other works are needed to keep the route going with an extra 1400t in each direction per hour etc etc...?Yes, but would the route now be viable for trains carrying the largest containers? Only after that point is established should consideration be given to possible consequential problems. The number of inter-model trains per hour running between Weaver Junction and Carlisle is not enormous so diverting them would not add huge numbers to a very lightly used route originally built as a main line.
You still haven't answered my question. Would single tracking through the tunnels be enough to enable trains carrying the largest containers to pass through without problem?No, you look at the consequences and requirements as a whole. Just becuase it was a main line 60 years ago doesn't mean anything. You don't do something and then say "ah, that bit doesn't work now, what do we do?" and then wait another 5 years before you can fix it. Do these diverted trains work across the WCML at Farington, Blackburn, Daisyfield, through the long block at Clitheroe and across the job at Carlisle, what impact is there to the journey time, what other works are needed to keep the route going with an extra 1400t in each direction per hour etc etc...?
No idea, im not a structural or gauging engineer. I will assume it does, but still not sure what that proves.You still haven't answered my question. Would single tracking through the tunnels be enough to enable trains carrying the largest containers to pass through without problem?
I think we all know that the orthodox opinion is that the Settle and Carlisle line is unsuitable for diversionary running.
