CrossCountry XC Class 170 refurbishment
23 Nov 2015
I disagree, this way phone chargers won’t be sharply twisted just beneath the plug when attempting to use the phone while it’s charging. The more this is done the more likely the charging lead is to stop working.
The usual position (how these would be if rotated as you suggest) is better for laptops on tables, and these will now be twisted slightly, but laptop charging leads tend to be a lot thicker and more robust than flimsy phone leads, so I consider this move an improvement.
Agreed, looks a sensible layout to me. Similarly, on the Anglia FLIRTs I like the socket being upside down between the seats - it’s far more natural to plug in that way when the socket is underneath the seat that twisting it around.
Amos390
22 Jan 2025
I can conform having seen the newley refurbished 170101 in person, they have kitted out the whole inside with charging ports, new seats, removed first class and the obvious new livery (attached)
Russel
30 Jun 2022
Whittington
Only issue with this is anyone expecting the plug to be the standard way up then rams the live and neutral pins into the 2 USB sockets, which probably explains why so many of the USB sockets don't work on the GA Flirts.
Bikeman78
26 Apr 2018
Yes, the FISA LEAN, also used on the Greater Anglia and TfW FLIRTs and the 196s.
It's not an uncomfortable seat, but its thick-backed frame does mean poor legroom. Though because the 170s had very thick backed seats before it might still give a small improvement.
The 170/1 were known for poor legroom when they were new. Has it improved with the refurb?
The_Train
2 Jun 2018
Totally agree with this assessment. They look perfectly positioned to me
Envoy
29 Aug 2014
Presumably nobody can see out if they are behind the cabs? How crazy is that?
Jacob Porrett
28 Jan 2022
Telford
Any progress?
Unfortunately at this moment in time I haven't been able to see the progress as it's in the wheel lathe and I don't go in there on a regular basis.
Any progress?
So I can give an update as the door is open. It has received the red livery colour now. That's as much as I can see.
PupCuff
27 Feb 2020
Nah, I've had that unit a few times, the visibility through the decals is fine. From that photo the level of opacity looks higher than it actually is, probably a combination of outdoor lighting conditions and the camera image processing.
E B
30 Oct 2024
Nuneaton
Ok, thanks a lot
Jacob Porrett
28 Jan 2022
Telford
Update on 170112: as of today the unit has now got the full livery applied to it and it's now receiving the cross country stickers on the side of the unit. Inside the majority of the seats are in position bar a few still need installing. A lot of electrical work is needed by the looks of it and today they had the information screens on testing them out. Hopefully should be out soon by the sounds of it.
Jamesrob637
12 Aug 2016
I hope I get lucky and have this or another refurbished unit on the 12:22 Birmingham to Stansted on 26.04
Jacob Porrett
28 Jan 2022
Telford
170112 has now had all stickers applied and all seats are now fitted. Work on the cabs needed still however but it's coming along nicely. I was told it was having an inspection today so fingers crossed that goes well.
vicbury
17 Mar 2012
Bristol
First trip on a refurbished unit for me this morning and I'm quite impressed. The exterior looks really good. The interior is nicely specced too, smart carpet and colours.
In the former first class section, the seats are a definite upgrade, with good back support and large seatback tables. My only criticism is that the edges of the seat base are quite raised and press into your thighs somewhat.
I do also like that the information displays are a simple white text on black background. Much more classy than on some other operators!
Chiltern006
3 Oct 2018
I am surprised that they didn’t go for info screens like what a lot of other TOCs have now (TPE, LNWR, Southern to name a few)
tfw756rider
30 Nov 2024
Wales
The "computer monitor"-style screens that are fitted to 195s/196s/197s/331s/TfW Mark 4s (on their own), 172/0/2/3s*/805s/807s (in addition to the "stretched bars") and 185s/350s/397s (in addition to the dot matrix screens)?
(I wasn't aware of Southern using those but I haven't yet travelled with them.)
TT-ONR-NRN
30 Dec 2016
Salford Quays, Manchester
The "computer monitor"-style screens that are fitted to 195s/196s/197s/331s/TfW Mark 4s (on their own), 805s/807s (in addition to the "stretched bars") and 185s/350s/397s (in addition to the dot matrix screens)?
390s too, now.
tfw756rider
30 Nov 2024
Wales
390s too, now.
Thought so, thanks, but I haven't actually been on one since the final days of Virgin.
Perhaps they were just not deemed necessary for whatever reason. With them though (in addition to the screens they did get), they would've been most similar to the setups on the 172/0/2/3s.
