Cryptic clues = station name
Discussion in 'Quizzes & Games' started by paulravuslante, 8 Feb 2011.
  1. Calthrop
    Calthrop Established Member
    1,707
    6 Dec 2015
    Right -- Jeremy Bentham, 1748 -- 1832, most renowned for the dictum: "it is the greatest happiness of the greatest number that is the measure of right and wrong".
    Sir, you succeed to the rostrum in the august discussion circle.
  2. DaleCooper
    DaleCooper Established Member
    3,403
    2 Mar 2015
    No.664 - Next door to the Beast
    Next clue:
    To describe it briefly: it's sticky and slimy and it's found next to rivers.
  3. Calthrop
    1,707
    6 Dec 2015
    If we were living seventy years ago, and the Stratford-on-Avon & Midland Junction route still had a passenger service: I'd say Towcester. What with the creatures in Alice Through the Looking-Glass called "slithy toves" ("slithy" = "lithe and slimy"); and Towcester being situated on the River Tove -- an open-and-shut case !
    However -- in the words of the Master: "as it isn't, it ain't".
  4. DaleCooper
    3,403
    2 Mar 2015
    Furthermore Towcester has only one river.
  5. backontrack
    backontrack Established Member
    5,631
    2 Feb 2014
    The UK
    Windsor & Eton Riverside?
  6. DaleCooper
    3,403
    2 Mar 2015
    WNR isn't sticky and slimy, is it?
  7. DaleCooper
    3,403
    2 Mar 2015
    Sorry I haven't been back for a while, my broadband was broken. Here's another hint plus elaboration of the two previous hints.
    Northern manages this station and provides all passenger services.
  8. cadoxton
    cadoxton Member
    27
    24 Dec 2014
    Seascale?
  9. DaleCooper
    3,403
    2 Mar 2015
    Seascale doesn't appear to have any rivers at all and SSC isn't sticky and slimy so no, Seascale isn't the answer.
  10. Calthrop
    1,707
    6 Dec 2015
    "Desperationsville" -- Steeton & Silsden??? Said station is in the Northern fold; and the names sort-of sound sticky and slimy; and Steeton is on the River Aire, and another stream -- un-named on my quite comprehensive road atlas -- flows from the north-east, into the Aire thereabouts.
  11. DaleCooper
    3,403
    2 Mar 2015
    That's not it.
    SON isn't sticky and slimy
  12. Seacook
    Seacook Member
    457
    17 May 2010
    West Bromwich
    I read these lines from the bottom up and thought it could be Staines (SNS) which is near something called Two Rivers. Then I read the bit about being managed by Northern...
  13. DaleCooper
    3,403
    2 Mar 2015
    ...and SNS isn't sticky and slimy.
  14. Harbouring
    Harbouring Member
    262
    20 Jul 2017
    Is it Goole?
  15. DaleCooper
    3,403
    2 Mar 2015
    Welcome to Cryptic Clues.
    It is indeed Goole (at the confluence of the rivers Don and Ouse) because GOO is sticky and slimy, your turn...
  16. Harbouring
    Harbouring Member
    262
    20 Jul 2017
    I will declare an open floor
  17. Seacook
    Seacook Member
    457
    17 May 2010
    West Bromwich
    Since the clue mentioned describing briefly S 'n' S could be short for sticky and slimy. (It could describe some stains as well.) It appeared to fit the clue rather well with the sole drawback of being entirely wrong.
    However, since the floor is open:
    What was left of Theresa May when the sea went out
  18. Calthrop
    1,707
    6 Dec 2015
    Yarm?
  19. Seacook
    Seacook Member
    457
    17 May 2010
    West Bromwich
    Of course.
    THERESA MAY - THE SEA ('went') leaves RMAY 'out' is the anagram indicator.
  20. Calthrop
    1,707
    6 Dec 2015
    Whereby my go, yes?
    By big bridge -- mixing it, swollen & cheap: Capek, Czech author
  21. Calthrop
    1,707
    6 Dec 2015
    Hint: station of national rail network, on line of same; also the site of a -- with minimal track in its own right -- preservation undertaking.
  22. backontrack
    5,631
    2 Feb 2014
    The UK
    Kirkby Stephen?
  23. backontrack
    5,631
    2 Feb 2014
    The UK
    wrong thread
  24. Calthrop
    1,707
    6 Dec 2015
    So, Kirkby Stephen is not your answer to this one? K.S. is indeed wrong -- the correct place is much further south.
  25. DaleCooper
    3,403
    2 Mar 2015
    Chappel & Wakes Colne?
  26. Calthrop
    1,707
    6 Dec 2015
    Correct: anagram of "swollen & cheap; Capek". Over to you.
  27. DaleCooper
    3,403
    2 Mar 2015
    Next clue:
    In court, if you want bail, lie stony-faced to the judge.
  28. Karl
    Karl Member
    618
    16 Aug 2011
    Bamber Bridge
    Baillieston
  29. DaleCooper
    3,403
    2 Mar 2015
    That's the one, your turn...
  30. Karl
    Karl Member
    618
    16 Aug 2011
    Bamber Bridge
    Help!!! Can I first apologise, but I can't help letting this one pass. :)
    The station to be masturbated on?
Share This Page
