Bertie the bus
- Joined
- 15 Aug 2014
- Messages
- 3,001
Just about every diesel hauled railtour on the mainline has 2 locos.Doesn't say much if they've to rely on a Duff
Not alwaysJust about every diesel hauled railtour on the mainline has 2 locos.
Very true....but the following West Coast railtour - hauled by 86 259 - didn't have a stand-by loco attached on the rear. Do WCRC have some kind of special dispensation?If a loco were to fail the cost of recovery in certain places would probably send the operator into administration, having a back up makes perfect sense
Electrics tend to be a tad more reliable!Very true....but the following West Coast railtour - hauled by 86 259 - didn't have a stand-by loco attached on the rear. Do WCRC have some kind of special dispensation?
From what I've heard, it's a known issue so will be resolved.I’m I right in thinking that the 2nd engine only cuts in over a certain speed (maybe around 25 ish)?
From what I’ve gleaned from various other forums it looks like the second power unit on 55022 has had to be removed for further work with a different one dropped in to keep the weight balance correct. I’m not sure of the timescale regarding getting it working on two engines again though.
Some heritage locos have their original TOPS numbers on the system but I think they have to apply for them, there is a ye olde thread about this somewhere, but there has been no 'Deltic' that can use their original TOPS number.It is 55022, also known as D9000, and therefore 89500.
Explained here:
https://features.rcts.org.uk/locomotives/tops-class-89/
In the same way, mainline steam locomotives are registered in the class 98 series.
I recall it is actually related to the power controller setting rather than physical speed, so you usually only see one black tower when it pulls out of a station, but once at speed and moving say 40 upwards, the controller moves to notch 6(??) then both engines kick in.Correct and correct. I heard somewhere in the range of 40mph.
The future LSL tours with this loco are cancelled due to mechanical concerns
I’ve often wondered about how it’s controlled too. Id guess, like you, there’s another driver in the rear loco some radio communication between the two drivers? Not sure the idea of sat gazing at the rear of a coach for hours on end would appeal though!Great to see a Deltic out and about again, I gather that the 47 did some work, helping out. Would this be powered from the Deltic cab?, or would it have been stand alone with a driver powering?. I presume there is radio comms between the Deltic and 47?
Well they can’t really win can they? If the Deltic only has one engine people will (justifiably in my mind) complain about that, and if the 47 ‘helps’ another sub-set of enthusiasts would probably take umbrage with that. I was booked on one of the tours and while I am disappointed with the cancellation I would rather do it in the future with full Deltic power available.Disappointing!
It’s a shame there isn’t a suitable substitute available, or perhaps a 47 on the back to provide more power.
Perhaps, reading between the lines, some of these tours haven’t sold as well as anticipated?
It's around 25, where can go to notch 6 without overloading.Correct and correct. I heard somewhere in the range of 40mph.
AFAIK, Deltics can't work in multiple with anything so the 47 on the rear would have a separate driver in radio contact with the front driver. Even if the loco was only there for heating purposes it would still need to be manned for fire precautions, a loco on the rear can only be left unattended if it is completely shut down.I’ve often wondered about how it’s controlled too. Id guess, like you, there’s another driver in the rear loco some radio communication between the two drivers? Not sure the idea of sat gazing at the rear of a coach for hours on end would appeal though!
Equally I’m curious as to the safety as to pushing at line speed with what I’d describe as buffer to buffer rather than a more solid link as with a DVT set? It’s obviously safe as it is the way, but I’m curious.
Hopefully someone will enlighten me…
That’s not the case. Locos can be left unattended at the rear if they are fitted with automatic fire extinguisher equipment. If that wasn’t the case we wouldn’t have push-pull working and HSTs would run with the rear power car always shut down.a loco on the rear can only be left unattended if it is completely shut down.
Deltics never had multiple working equipment and nor did 47s until retrofitted on some locos.AFAIK, Deltics can't work in multiple with anything so the 47 on the rear would have a separate driver in radio contact with the front driver. Even if the loco was only there for heating purposes it would still need to be manned for fire precautions, a loco on the rear can only be left unattended if it is completely shut down.
Multiple working through the train (as opposed to having a driving trailer one end) is fairly rare in the UK but quite common in certain parts of Europe.
Final repairs to be carried out by Harry Needle.I've just passed D9000 running light engine from Crewe to Barrow Hill
Would have thought the DPS would have a bit more knowledge.Final repairs to be carried out by Harry Needle.
D9000 isn't a DPS machine and doubt they'd have the time to work on another person's loco.Would have thought the DPS would have a bit more knowledge.
I know 55022 isn’t a DPS machine, neither is it a Harry Needle machine either, but I would have thought at least conversation could have been discussed with a certain group that have operated Deltics for the past 40 years to take advantage of the knowledge they have.D9000 isn't a DPS machine and doubt they'd have the time to work on another person's loco.
Why would the DPS freely give their knowledge to a commercial organisation, which is what Loadsamoney Services is?I know 55022 isn’t a DPS machine, neither is it a Harry Needle machine either, but I would have thought at least conversation could have been discussed with a certain group that have operated Deltics for the past 40 years to take advantage of the knowledge they have.
A rather odd comment. HNRC’s bread-and-butter business is overhauling ex-BR diesels.I know 55022 isn’t a DPS machine, neither is it a Harry Needle machine either, but I would have thought at least conversation could have been discussed with a certain group that have operated Deltics for the past 40 years to take advantage of the knowledge they have.
Maybe because they like Deltics? I’m not saying they should give advice freely, but I would have thought even just an informal chat with with with someone at the DPS wouldn’t be a bad thing.Why would the DPS freely give their knowledge to a commercial organisation, which is what Loadsamoney Services is?
Still not sure what your point is? Knowledge is all well and good for understanding schematics and diagrams, but as I've pointed out, HNRC's business is repairing and overhauling ex-BR diesels.Maybe because they like Deltics? I’m not saying they should give advice freely, but I would have thought even just an informal chat with with with someone at the DPS wouldn’t be a bad thing.
Im not sure what your point is regarding what a Deltic is. Are they not ex BR Diesels, I’ve always understood they were on TOPS as 55001 to 55022? Or did I just dream that?Still not sure what your point is? Knowledge is all well and good for understanding schematics and diagrams, but as I've pointed out, HNRC's business is repairing and overhauling ex-BR diesels.
@fgwrich's post was that 55022 has gone to HNRC for final repairs. HNRC is a company that does repairs and overhauls on ex-BR diesels, i.e. English Electric and Brush locomotives. What has a conversation with the DPS got to do with sending a loco for repair?Im not sure what your point is regarding what a Deltic is. Are they not ex BR Diesels, I’ve always understood they were on TOPS as 55001 to 55022? Or did I just dream that?
My point is it seems nobody from LSL seems to have asked someone with a knowledge of Class 55’s ‘can you help us with this please?’
There’s a group at Barrow Hill (and a previous owner) that might be able to point LSL in the right direction.
I believe 55022’s previous owner was quite happy to have dialogue with the DPS about Deltic operations, I find it rather baffling that LSL haven’t done something similar.
What’s difficult to understand about that?
What particular Class of loco is being sent for repair? Look at the thread title.@fgwrich's post was that 55022 has gone to HNRC for final repairs. HNRC is a company that does repairs and overhauls on ex-BR diesels, i.e. English Electric and Brush locomotives. What has a conversation with the DPS got to do with sending a loco for repair?
