CardiffKid
Hi, Can someone please succinctly summarise the differences (technical or otherwise) between a 142 and 143 train for me?
The class 144 underframes are BREL and they were built at Derby, rather than Hunslet-Barclay at Kilmarnock.I'd like to know the difference between a 143 and a 144, because there appears to be no difference at all
Class 142: Built by BREL at Derby, Leyland body panels derived from the Leyland National bus and assembled in Workington. Steel underframe, riveted steel body and roof. Built with roof mounted 'pod' heating units derived from the Leyland National.
Class 143: Built by Hunslet Barclay at Kilmarnock, Walter Alexander bodies. Steel underframe, aluminium alloy body and roof.
The Pacers get a hard time from people. These units saved lines from closing. It's also worth noting that compared with other units they are remarkably reliable. Love them or hate them they've done the job!
This is often said, but I'm not sure how true it is. Although it was the height of Thatcherism I'm not convinced that widespread closures would have been acceptable politically. The Serpell report was rejected for a reason.The Pacers get a hard time from people. These units saved lines from closing. It's also worth noting that compared with other units they are remarkably reliable. Love them or hate them they've done the job!
The Pacers came about as a cost-saving measure, and also provided work for state-owned Leyland. The alternative wouldn't have been closure in most (if not all) cases, it would have been refurbishment (and maybe new engines) of the more structurally sound heritage units followed by a larger build of Sprinters.
Alhough they're past it now, they've done a decent job of ferrying folk about over the years. There's a few things about them that are quite good, like the big windows and (in some cases) low-backed seats which make them seem spacious, if they're not completely full... not sure I'd want to be on one if it crashed, mind!
........................The alternative wouldn't have been closure in most (if not all) cases, it would have been refurbishment (and maybe new engines) of the more structurally sound heritage units followed by a larger build of Sprinters...............
i know that if you're trained on e.g. 142s and 143s you'd need conversion to 144s, so there may some small differences between the Pacer classes in that regard. Not sure what they are though!In terms of being a driver or guard, is there any difference?
I understand that all the 142/143/144 network Pacers (as well as 141-113) were re-engineered in the 90s (the original Leyland TL11 engines and SCG gearboxes were all replaced with Cummins LT10Rs and Voith hydraulics).143’s and 144’s are identical mechanically
I don't like how for the 142s the original running gear isn't mentioned at all, and oddly for the 143s and 144s it partially is (SCG but no Leyland)This may help:
http://www.railway-centre.com/class-142.html
http://www.railway-centre.com/class-143.html
http://www.railway-centre.com/class-144.html
Extracts from Colin Marsden's books and Modern Railways Illustrated
That page for the 142s also says that the body structure was "Aluminium Alloy (bus body sections) on steel frame". I was under the impression that the panels on the Leyland National were galvanised steel, and that the 142 more or less used standard parts with some extra components to provide the extra width.I don't like how for the 142s the original running gear isn't mentioned at all, and oddly for the 143s and 144s it partially is (SCG but no Leyland)
agree with what...?Agree but they shouldve gone 10 years ago.. and are used on some longer distance services than they should be so i understand the hate for them
The 142 was based on the Leyland National bus, weren't the 143 and 144 Pacers based on a single deck bus being produced by Alexander at the the time ?
You're forgetting why so few DMU classes were upgraded: asbestos
What you suggest would never have happened
Which is why I mentioned structural soundness in my initial post in the subject. Bu definition this would rule out the worst of them i.e. the 108s, those with asbestos, the 104s which were rather rusty.Structural integrity was another issue. Regional Railways had a proposal to refurbish large numbers of 108s for service in the 90s and beyond, but it was found the lightweight aluminium bodies had become brittle and weak over time, making their crashworthiness somewhat alarmingly bad. The 101s were selected instead.
No, the 143/4 body was bespoke, as far as I know, though presumably it used Alexander's usual bus construction method (aluminium panelling on aluminium frames).
