As we are on a rail forum we obviously all like trains, but we should be honest about the successes and failures of the busway while bearing in mind that it isn't the busway's fault that it was built on something we would rather have seen as a railway. It cost more and took longer than it should have, yes. But this has also happened in places like Edinburgh Trams and Sheffield Tram Trains. Perhaps most pertinently, it also also happened in the construction of the Cambridge North station that would have been part of the railway line that we would all rather have seen.
But that is it. No bus has bounced off it, but four buses have crashed into to the junctions on entry. In the same period a bus also ended up on Jesus Green and various other non-guided bus accidents have happened, because sometimes that happens with busses; it's not a guideway problem. Motorists do regularly drive on it, but motorists also regularly bash level crossing barriers and railway bridges.
The cycle path is amazing, but it not the main success at all. The main success can't be overstated; the main success is that (as much as it may annoy us all and is illogical), passengers demonstrate absolute love for it in the key way that matters. The passenger growth could never have been believed; it has been absolutely spectacular. We now have well over 30 busses arrive in Cambridge from the north before 9am (is it 34 at the moment?), many of them rammed. This is startling enough on its own, but is all the more remarkable when you consider that every other bus route around or out Cambridge except one (the X5) has seen terrible decline. Bus services in Cambridge that have not been halved as a result of declining passenger numbers brought about by unreliability caused by congestion are the exceptions to the rule.
The next thing sad thing we have to accept is that if the guided busway had been opened as a railway we would have bungled it. Awfully. There'd be something like an hourly two carriage service from St Ives to Cambridge, and capacity and frequency wouldn't have been quickly expended when the need became clear. If it was a railway it would have needed to have been a metro style service with a 6/7 min frequency, and never in a million years is that what it would have been.
