DMU/EMU with snow blades?
TheEdge
29 Nov 2012
Norwich
Quite a lot do, a quick google looks like the 150, 153, 156, 158, 170, 171 and 172 all have small ones fitted.
swaldman
19 Jan 2013
I'm guessing that if there's any question as to how much snow, they'd rather have a light loco have to stop / use a spade / turn back / whatever than a service with passengers on?
61653 HTAFC
18 Dec 2012
I believe these are actually deflectors rather than snow blades.
I believe so too, the base of the blade has more clearance from the railhead. That is unless the WHL 156s have proper snowploughs, which wouldn't surprise me.
380101
18 Feb 2015
They just have the standard deflector blade like all the rest of the ScotRail 156 fleet.
alexl92
12 Oct 2014
Do 158s have them? They do have a deflector kind of thing to stop large objects going under but it’s not really a blade like 155s have, for example.
whhistle
30 Dec 2010
I'm surprised trains don't have pipes blasting air in front of the train on to the tracks.
Simply blast the snow away...
DarloRich
Fenny Stratford
Even if you increased the rate of blast?
But when you get to aeroplane speeds [of blast], the train simply wouldn't move I guess :P
I suspect that for small amounts of loose snow it might work but if it was compacted or deep the pressure needed would be prohibitive. Sadly, my idea of fitting flame throwers was rejected.
Cowley
15 Apr 2016
Devon
I expect it was shot down in flames along with my idea of retractable train skis.
There’s just not enough thinking outside the box these days...
Parallel
9 Dec 2013
I’m not sure but GWR 158s have larger deflectors/ploughs than the SWR ones. I’ve got a picture somewhere of the 158s coupled, and you can see the difference!
Marklund
18 Nov 2010
I guess Scotrail decided it was worth fitting plough shaped deflectors at some point.
brel york
4 Feb 2011
the plant
The one on the Class 150 is called a snowplough, lifts on and off with fork lift truck (if you undo the bolts lol)
Chris125
12 Nov 2009
Jet engines have been tried, but it wasn't very practical - a blast strong enough to clear snow and ice won't be too kind to the track either.
