Does cable theft still happen?
thenorthern
27 May 2013
While I was talking to someone on the phone this morning about taking metal to the scrap yard and how they require payment to be made by credit, name taken down and ID to be checked to cut theft.
A couple of years ago though there were incidents pretty much every day of cable theft and metal theft but these seem to have now gone.
Does cable theft still happen today though and how common is it?
Darandio
24 Feb 2007
It certainly does seem less apparent up here, it was a near weekly problem. The last couple of times it's happened since the new measures have not been theft, but just cutting the cables. Probably more out of spite than anything.
broadgage
11 Aug 2012
Somerset
Yes, as others post, cable theft is still a problem but less serious than was the case a few years ago.
As well as the stricter laws regarding selling scrap, the declining price of copper has probably helped.
I also wonder if the current security situation is helping indirectly ? Transport infrastructure and passengers are favourite terrorist targets, and are therefore receiving extra attention from the security forces.
This extra attention probably discourages ordinary thieves as well as terrorists.
thenorthern
27 May 2013
Smartwater according to Network Rail has been a good deterrent as it has a 100% conviction rate.
There have been a fairly large amount cable thieves electrocuted and killed which must be sad for the families but I don't think most of the public are too bothered about criminals being killed in the process of theft.
There's hearsay evidence that fibre optic is often cut and left in situ in a failed search for copper. Similar effect on the railway as actually knicking it of course...
furnessvale
14 Jul 2015
That is true but fortunately the experienced thief quickly learns to recognise fibre optic cable and leaves it alone.
Hellzapoppin
16 Jan 2016
Fibre optic is written on the cable so I suspect some of the thieves have learnt how to read.
However, some fibre cables are green and heavy which I suspect is mistaken for earth cables hence it being cut and left.
It's not hearsay - BT is affected by it on a weekly, if not more frequent, basis.
dk1
2 Oct 2009
East Anglia
Thankfully it's massively reduced. Occasionally hear it happening but they must be either desperate, thick but probably both.
ScouserGirl
28 Dec 2015
Cable theft doesn't happen as much now but there have been a few incidents off late especially in the Nottingham area.
Even had one on the Eurostar near Lille last year. Thus proving it's not just a British problem!
alb1
13 Apr 2015
There was overnight cable theft near Treherbert, causing delays to services and bus replacement.
gimmea50anyday
8 Jan 2013
Back Cab
An attempt was made at Darlington a couple of months back. Managed to cut one end but must have been disturbed or found the cable was fibre optic and buggered off. Since the new rules kicked in not had any actual thefts noted although had a couple of vandalism instances. Huge improvement.
PHILIPE
14 Nov 2011
Caerphilly
There must still be a "rogue" dealer in the area following legislative registration with recent frequency in the Cardiff Valleys.
thenorthern
27 May 2013
I know its not politically correct to say it but a large amount of the rouge dealers are gypsies particularly Irish Travelers which makes it harder to trace as most of them aren't registered companies and the owners aren't on the electoral roll.
Deerfold
26 Nov 2009
Do you have anything to back up this sweeping statement?
Steveman
24 Feb 2016
In Romania Roma gypsies have turned to taking whole sections of in use track for scrap and it's getting worse.They started with bolts and clips but now take the rails as well.
Now they are over here in force how long before they start on ours.
Deerfold
26 Nov 2009
Your first link contains nothing in terms of statistics, reporting on comments from an anonymous source and then saying
Indeed, the crackdown by police on scrap-metal merchants is believed to have resulted in the rise in prominence of organised Roma gypsy criminal gangs, who ship stolen metal directly out of the country
With no indication who thinks this or with any evidence that it is true.
Your second link gives no indication that travellers are likely to break this law, merely warns them of its effects.
ctom_s
23 Dec 2015
Hornchurch, Essex
It was mentioned earlier but the declining copper price (halved since 2011) has definitely contributed to this.
I had also heard that traveller groups were often involved but never looked into it in detail
Carntyne
8 Jul 2015
Vandalising and stripping out location cases seems to be the new 'in' thing.
Groningen
14 Jan 2015
It is also done in the Netherlands; so nothing there. Countries with only diesel have nothing to fear! April 1st; last time between Rotterdam and Gouda.
