Does failing an MMI cost you a “life”? Advice needed
Thedispatcher
7 Feb 2016
Hi there,
Just wondering if anyone knows whether failing an MMI counts as a lost life in applying to drive. Also, have got one coming up and would appreciate any tips or advice on what to expect.
Cheers.
GMT
29 Aug 2015
Kent
Hi there,
Cheers.
My advice would be to Google MMI or Multi Modal Interview and see what you get. Use the search link on this forum; again, type MMI or Multi Modal Interview. As to what to expect, it should be explained in the material the TOC should have sent you. You should be asked six questions. Something resembling the ones below:
Describe a time where you've had to follow rules & procedures:
Describe a time where you've been involved in an emergency situation
Describe a time you've been on a training course for over 2 weeks or your greatest achievement
Describe a time where you've had to work for long periods of time alone
Describe a time you've had to solve a difficult problem
Give an example of undertaken task similar to train driver's role
and good luck.
danielg
21 Jul 2017
Hi there,
Cheers.
Hi, I've been told it doesn't. I was only informed about the assessment day where if any one person fails twice thats it.
A friend of mine has failed two manger interviews and passed on his third. If that's anything to go by. Each interview was with a different TOC if that makes a difference.
Dynamonic
10 Jan 2013
Nottinghamshire
Hi danielq,
I believe you may be getting the two different interviews mixed up.
Failing the Multi-Modal Interview (MMI), which is part of the Stage 2 OPC Assessment, does count as a life lost I'm afraid.
The interview I believe you're referring to is the Driver Manager Interview (DMI), which is set by the TOC, and typically doesn't have 'lives'. :)
Your friend would have passed the 'DMI' on his third attempt, as the 'MMI' can only be attempted twice by a single person across all TOCs. (They all have the same MMI)
danielg
21 Jul 2017
Hi danielq,
I know there's a difference between the two interviews, I was just adding to the convo but good to know, wasn't told about this. Cheers
