I’m not suggesting we single any existing lines (maybe close some, sure, but single tracking can be a lot of expense just to save small annual sums so feels fairly pointless)
However, there may be examples where you have a branch line that isn’t realistically going to ever demand more than the current service provision (e.g. Burnley to Colne won’t ever need more than an hourly service, there’s no freight, it’s a dead end with no junctions beyond the chord at Burnley, it’s just a glorified siding which will only ever have “one train in steam”)…
…on that branch we have a station like Wennington (which is on the double tracked Bentham line). At Wennington right now, services are unable to call in one direction because the footbridge is knackered. So we are running a replacement bus service and will no doubt spend tens of thousands of pounds on repairing the bridge (because nothing is ever cheap).
The problem is that Wennington only gets half a dozen departing passengers a day (a lower number than the eight trains a day in each direction scheduled to stop there).
So I could see the logic in someone deciding that if we had a station like Wennington on a branch like the Colne route then it’d be better to have single track (with everything serving one platform) than rebuilding a footbridge to a second platform
Clearly that’s just a hypothetical case (the Colne line was singled some time ago, Wennington is on another route entirely), but this seems to have been the decision on routes like the (much busier) double track Durham Coast line, where I guess someone at BR decided that it’d be “better” to install points at Hartlepool for everything to serve the western platform than to refurbish the eastern platform (so whilst the line remained double track, all southbound passenger services crossed over to serve the northbound platform instead)
But such cases are thankfully rare and we live in more enlightened times than the penny pinching Hartlepool example
However, there may be examples in the future where a contractor quotes such a huge sum to repair the crumbling “Platform 2” at a station (including footbridge , lift, security concerns etc) that Network Rail decide to stick in a couple of points and focus everything on “Platform 1”
The problem is how you ever
reverse such a decision - I think this calls for a Penryn style solution!
Have there been any major singling of existing routes post-Beeching (apart from maybe Ribblehead viaduct to help reduce strain on the viaduct)?
I can’t think of any “major” (i.e. long distance) examples other than those cited by others on the thread
But one frustratingly short one in this neck of the woods was British Rail’s 1980s decision to replace the chord at Dore with single track (it’s only a short section but it has huge regional consequences)
Often there may be merits to a single track lead at a junction (as well as reasons not to) but in this case it’s meant decades of reliability problems and the service to this suburban station being severely limited
BR’s decision to have the one remaining platform on the single track section between the double track MML and the double track Hope Valley line, so the “fast” services on the long distance lines mean there’s very little scope to stop anything at Dore because a one minute dwell is going to eat up a lot of capacity in the opposite direction
The Hope Valley line also has a single track chord near Hazel Grove, so everything from South Yorkshire to Greater Manchester feels set in stone in the timetable with very little flexibility, which is a huge problem when you are dealing with a conflict like a Liverpool to Norwich train that might clash with a long/ heavy Cement train - planners lack the ability to tweak the paths by a couple of minutes because the timings at the two single track chords feel set in stone (the line is complicated enough given the gradients/ Peak District weather/ long tunnels etc)
