Although I am aiming this query at Southern drivers I'll just explain for others what I'm on about...
On the older generation 377's the hill start button is on the power/brake controller, to move away you hold the button in which keeps it in a step 1 brake application while you move the controller through the neutral position and into a power notch, when you feel the unit beginning to pull you release the button, the brake comes off and away you go.
On the 377/7 (and on the 387 which is why I'm asking) the hill start button has been moved to a new location on the desk. You press the button and it lights up and the brakes are held on and - his is where it differs - you must select at least NOTCH 2 POWER and then when the unit's computer senses that enough power is being taken then it releases the brake for you. Simples.
So, when coupling up in an older 377 you simply hold the button in, select notch 1 - which is the advised power notch for coupling - release the button and it moves slowly forward for a nice smooth couple.
So the questions (eventually got here) what is the procedure for coupling in a 377/7? The guys who have attended the 387 brief have come away with some notes and a DVD but are none the wiser and when asked about this the trainers aren't too sure either. And the southern guys I have spoken to haven't had to do it thus far and they aren't too sure either.
Do you select notch 2 then quickly drop back into 1? Or does this result in the unit lurching unceremoniously forward into a heavy "controlled collision"? has anyone got a technique or seen a published procedure? Or do we just wing it on the day
Edit: searching the forum there has been some mention of this, is it on the desk in a 377/6 too? And 379 ? How have drivers got on with the desk mounted button?
