DRS Mk2 Push Pull
GM228
9 Feb 2015
I'm curious as to what system the DRS Mk2s use for the DBSO? Have they been modified to use the DRS type multiple working system or another type or both?
GM228
colchesterken
On the same subject does anyone know why Abellio seem to have given up on cl 37 s and DBSO s on the Norwich local routes, it seems a bit of a waste using 2 x 37 s for 2 coaches
GM228
9 Feb 2015
Also the requirement for a driver in each loco! Perhaps they will get a DBSO in the future when more become available?
GM228
Smudger105e
5 Jan 2010
N 52° 53.492 W 001° 15.493
GM228
The Mk2s have had through 27 way jumpers fitted, and connect to the 37 using the standard blue star jumpers and recepts. There is an additional jumper from the DBSO for the CDL and PA and the RCH jumpers for lighting control.
GM228
9 Feb 2015
Why did DRS go to the trouble of fitting their own type of MW system to the 20s and 37s when they already had the blue-star? I thought blue-star was disconnected with the DRS system in place, but obviously not!
GM228
Smudger105e
5 Jan 2010
GM228
It is connected to the train lines in the nose end. Some locos have both (e.g. 37401, 716) and some have no blue star jumpers, just the DRS type 29 receptacles (eg 37069).
GM228
9 Feb 2015
Thanks for that, so do the 20s still retain blue star or just the DRS type?
And here's one for thought, can you multiple 3xlocos as follows-1xblue star only/1xboth/1xDRS type? In otherwords the 1st loco talks to the second via Blue star and the second talks to the third via DRS type?
GM228
Edit: having looked into this I'm told the DRS type is identical to Blue-Star and just wired up through a different socket and a DRS only type can apparently be used on normal Blue-Star systems using an adaptor cable?
10 Mar 2015
By my understanding Northern have used them all on their 37 sets, none left for Anglia.
Smudger105e
5 Jan 2010
That is correct, 1 wire on the blue star is connected to 1 wire on the DRS type 29, 2 to 2 etc. The only ones that are not connected in this order is some of the 7 and 8 wires, depending whether it is a jumper or a recept and whether it is at No1 end or No2 end of the loco.
There are only 2 there at the moment (9705 and 9707) although a further three are undergoing refurb and safety system upgrade at RVEL currently.
GM228
9 Feb 2015
So 3xDBSOs to NR (1 spare) and 1 DBSO to GA and another one to play around with could be realistic? Have DRS anymore in store?
GM228
Smudger105e
5 Jan 2010
GM228
Sorry, you misunderstand what I thought I had said.
The three that are being worked on at RVEL are all DRS DBSOs so that will eventually mean 5 in service with DRS. The NR ones are additional to these ones. I can't remember all the DRS numbers, but one is 9710, with 9707 and 9705 at Carlisle.
Observer
3 Nov 2014
Aren't there DVTs in storage? How about getting them restored to service, rewired to work with what would be on the other side and put to use?
GM228
9 Feb 2015
I know exactly what you meant!
Yes 5 DRS DBSOs, 3 for the NR operation as in Northern Rail for the Cumbrian jobs! I take it you think I'm referring to Network Rail?
In other words I'd guess DRS could allocate 3 to NR (1 rolling spare), one to GA and another spare as required!
GM228
theblackwatch
15 Feb 2006
DRS actually have 6 DBSOs now, 9704/05/07/09/10/13. As I understand it, the next one out should be 9713 for use in Scotland.
GM228
9 Feb 2015
If that's the case then the DBSO (and coaches) will need more mods to talk to the 68s won't they?
I thought the Scotrail sets weren't getting them which is why they have matching brake coaches unlike the Cumbrian sets?
GM228
Smudger105e
5 Jan 2010
GM228
Yes indeed, I read what you wrote, thought you meant NR being Network Rail, made some assumptions, which proved to be wrong, and am I drivelling on enough?
dk1
2 Oct 2009
East Anglia
AGA are hoping to get a DBSO in the formation at some point. In the meantime they are being compensated in the deal by DRS & Northern are paying the fuel costs on the second loco. No second driver currently required but this will not be the case when either loco is substituted.
GM228
9 Feb 2015
AGA required a driver in each 47, is this not the case with the 37s?
GM228
dk1
2 Oct 2009
East Anglia
GM228
No, they are through wired hence they both power up. This enables the leading driver to know if fire alarms sound in the rear loco.
GM228
9 Feb 2015
I thought that may be the case, super power for such a small load.
Are all the DRS Mk2s fitted with through pipes?
Could be because 47s have no jumpers. They are not blue star.
Yes was due to the possability of a fire or other problem in the rear loco and not knowing about it but didn't know they actually connected both 37s, saves on the extra driver but increases fuel usage I'd imagine although in the winter season would reduce slipping when starting.
I'm curious how DRSs green circle 47s work with Carolines blue star MW? Either some sort of adaptors or Caroline actually has more than one type of system fitted?
GM228
alexl92
12 Oct 2014
If I understand correctly, DVTs can't work with MK2s or with Cl 37s because the DVT uses the wiring system on the Mk3s which uses a TDM to control the other loco... so I think it'd be a fairly big job to make that one work.
GM228
Has Caroline worked with a 47? Every photo I've seen has been 37-powered.
cj_1985
6 Mar 2010
I could swear that i've seen a picture of a 47 with the observation saloon.... certainly within the last 7 months
Strathclyder
12 Jun 2013
Clydebank
This is the earliest dated image of a DRS 47 running with Caroline that I've found from a quick search (dated 17th September 2014).
GM228
9 Feb 2015
Yes the DVTs use the TDM system, the Chiltern and AW ones are modified for AAR AFAIK.
I saw a photo somewhere in 2013 also, has become more common since the 47s were displaced from AGA. Must be by use of some sort of adaptors or Caroline is so equipped?
GM228
barrowjack
18 Jun 2015
Barrow - Home of the Bluebirds!!!
The Northern services aren't using a DBSO either yet, though 9705 is now at Kingmoor. They are currently being worked by a 37/4 on one end and either /0 or a /6 on the other.
dk1
2 Oct 2009
East Anglia
DBSOs & DVTs both work on the same TDM principle & are interchangable with most standard MK2/MK3 LHCS vehicles. Exceptions are the ex-GatEx MK2s & HST MK3s.
GM228
9 Feb 2015
When the DBSOs first were introduced they workes using TDM with modified 47s for Scotrail and used the same system until retirement from Anglia, but the DRS DBSOs have blue-star mods and the Chiltern DVTs (also the Arriva DVTs???) have AAR mods, do these mods get rid of the TDM MW or supplement it?
GM228
