William3000
I would be very interested to gain other people’s opinions on the proposed East West Rail Mainline’s interchanges with other mainlines it crosses. From east to west, it is proposed to interchange with the West Anglia Mainline at Cambridge; the East Coast Mainline at St Neots South; the Midland Mainline at Bedford; the West Coast Mainline at Bletchley; no interchange with the Chiltern Mainline at Bicester; and the North/South Cross Country route at Oxford. I appreciate there are also proposal to continue it along existing lines to Norwich and Ipswich, and to Swindon and Bristol.
It seems to me that in order to get the biggest benefits out of this line, the interchange options are fundamental. Bearing this in mind I don’t see too many issues at Cambridge as all scheduled trains stop there so interchange options will inevitably be good.
St Neots South will presumable see all Thameslink/Great Northern services stop there in addition to St Neots which is two trains per hour but it seems unlikely that faster LNER services will stop there given some already do at Stevenage and Peterborough. But is there a case for some additional LNER trains to serve it, particularly given it may be the quickest route north up the East Coast Mainline from population centres at Milton Keynes, Bedford and Cambridge? It seems unlikely but is there scope? I note that some of the consultation documents mentioned services to Leeds and Edinburgh so is there a thought that some LNEE services may stop?
The next interchange westwards is Bedford. Bedford appears to have lost several of its longer distance services to Nottingham/Derby/Sheffield in recent years but is there scope for some additional services to stop?
I think Bletchley is interesting. Bletchley was once the major west coast Mainline stop in the area until the construction of Milton Keynes Central. For me this is potentially the most important interchange of all and the one with the greatest potential as it would provide the quickest links from Bedford and Cambridge to Birmingham, Liverpool, and Manchester. Clearly long distance trains can’t stop at Bletchley and Milton Keynes Central but it would appear to me that there may be a case for Bletchley to once again become the main interchange for the area. There is a lot of economic growth around there and the Milton Keynes Dons stadium is close by. But equally not stopping the inter city trains at Milton Keynes Central would be unpopular for the businesses in that area. I’d be interested to see an analysis of the pros and cons of each. I understand that some of the trains from Oxford will run on to MKC but not sure it’s possible from the Cambridge direction without reversing bays at Bletchley or a north facing curve.
Next is Bicester where there is no proposed interchange. Bicester Village station, clearly has to be located where it is but I wonder whether closing Bicester North and building a replacement Bicester Interchange where the two lines cross would provide sufficient benefits to justify what would be very expensive. It seems to me that of all the lines this is probably the one that could make do with no interchange as I imagine flows of passengers wishing to change would be limited - the only thing that may justify it could be improving rail links from the Midlands to Bicester village.
Finally Oxford I think is similar to Cambridge - the issue here is really platform capacity but as all scheduled trains stop at Oxford, interchange opportunities will be good.
so in summary:
Cambridge: interchange opportunities good
St Neots South: interchange opportunities likely only with Thameslink/GN services so of some but limited benefit but some scope for LNER services to stop but seems unlikely long distance passengers would want to slow their service but maybe scope for some to omit Stevenage and stop at St Neots South instead?
Bedford: interchange facilities good and maybe scope for some additional long distance trains to stop
Bletchley v MKC: which should be the inter city stop? Pros and cons of both but to me Bletchley makes more sense but equally I can’t see it happening
Bicester: limited passenger flows so probably unlikely that interchange will be provided
Oxford: good opportunities
I’d be really interested to hear others’ views.
so in summary:
