The Strategic Urban Extension for southeast Milton Keynes is focussed to the east of Bow Brickhill, between Old Farm Park and Woburn Sands. The relocated Woburn Sands station in Concept 2 would be pretty much in the middle of it.
The relocated Lidlington station in Concept 2 would be roughly a mile from Marston Moretaine. It would be about 5mins extra walk compared to the Millbrook station.
The relocated Stewartby station in Concept 2 is pretty much the same distance from Wixams as the current Kempston Hardwick station and would be broadly in the centre of an area currently being promoted for additional development.
Ridgmont station is proposed for relocation in both Concept 1 and Concept 2. It would be a roughly 15mins walk from the current station using existing roads. Part of the reason for this relocation is because the triangle north of Aspley Guise and west of the A421 has been identified as an area for growth so the new location would be on the ‘right’ side of the M1 to serve that.
A key part of the jigsaw is that any relocations would have to be as part of a wider package of improvements across the local area, such as proper cycleways and footways. There is also the opportunity to make possible provision for car parking which would be much more difficult at the existing sites.
As others have said, the purpose of the consultation is to obtain people’s views on what the priorities should be: (1) retain the hourly all stops branch service and add EWR on top; (2) consolidate the number of stations, but up the frequency at all of them; or (3) something else.
Similar arguments hace been used before to try and shut those stations, Kempston Hardwick in particular.
Taking Kempston Hardwick as an example. The existing atation is on the direct road that runs under the midland main line into Wixams. Do you really think a new road or footpath will be built across the midland main line from Wixams to the relocated Stewartby station roughly midway between the current Stewsrtby and Kempston Hardwick stations?
There is an off road walk from Marston to Millbrook Station via the country park. The relocated Lidlington Station will be significantly further away with walking along unrestricted roads required. I would also dispute the 5 minutes extra.
The proposed relocation of Woburn Sands is minor, about 100 yards albeit with an entrance at the MK end which will serve the new development. It doaent serve Bow Brickhill Caldecote or Tilbrooke.
You breezily say a 15 minute extra walk for people from the relocated Ridgmont Station to the old one. So workers at Amazon have a 20 minute walk instead of five minutes, both ways, every day and across the M1 Junction interchange to boot. That is considerable hardship.
I assume from your posts that you are an insider. Did nobody discuss this with the BBRUA to gauge what might or might not be acceptable to them and gain greater understanding of existing usage patterns before publishing options? I'm not a member, but I've always found them very responsive.
EWR appear to have just proposed the bighest branch line station closure proposal for decades, stations that people have fought tooth and nail to prevent closing three times already over the last 50 or so yeara. Was this really wise? Did they expect applause?
Fiennes said of Beeching that he had two flaws. An over fondness for maps, and an over fondness for publishing them. (This was in the context of Fiennes despairing that having quietly closed branch lines in the 50s with little fuss the uproar the beeching report caused made the whole thing far more difficult).
It's not really "shutting" 5 stations though is it?
It is proving 5 band new, modern stations (with a considerably improved train service), placed to optimise access to new developments and existing communities across the route as a whole, whilst also considering access to any new locations in terms of walking, cycling and car park provision.
Most people would rather travel a bit further to a relocated station if access is easy and a better service is available as a result.
A genuine opportunity to place stations fit for the community for the future.
There are ten stations. There will be five. That is shutting five stations.
BR tried similar closures in later years such as closing Redruth and Camborne and replacing them with a new station at Carne Brea.
They generally failed to get off the ground for much the same reasons as this proposal likely will (with the possible exception of Aspley Guise), namely that it was convenient to drive to but not convenient to walk to for either community.
