One of the biggest challenges in planning and operating a high-frequency route is preventing buses bunching, or in other words getting too close to one another. It’s a common occurrence, most often caused by one of the buses running late, which means it picks up more passengers than intended as those passengers were meant to catch the next bus. This in turn makes the bus even more late and continues a vicious cycle of late running > extra passengers to pick up, until the bus behind catches up with it, having been sped up by fewer passengers to pick up.
Once two (or three, four, or more) buses have bunched, there is no easy way to unbunch them as the buses will keep constantly overtaking each other as they alternate between stops to pick up passengers. Even so, I am aware of a couple of methods which could help prevent this endless spiral of bunching:
The first is to send an empty bus partway along the route and pick up service from a specific point. This can work depending on the speed and congestion of nearby roads, but in many cases it rarely closes the gap in the route’s headway. An example of this was when Barrack Road in Christchurch was closed last Friday due to a serious accident. The 15-minute headway 1a route was diverted via The Grove and Fairmile Road, but with few alternative routes in the area, the area was gridlocked. Morebus’s bus tracker showed no buses at the eastern end of the route, and a bus running fast along the A338 Wessex Way, which I presume was to close the gap in headway. Even so, the sheer volume of traffic meant there were still two buses bunched at once and a 30 minute gap between them.
The second is to do what London does and hold buses at a stop for a few minutes if they are catching up with the bus in front. This works to keep headways on track but at an inconvenience to passengers who have to face slower journey times, and also does nothing to close the gap created ahead of the delayed bus.
I wonder if there are more effective ways of keeping bus route headways to form, such as allowing fast running or skip-stopping of buses that get delayed or end up bunched.
