Does any 1 know what the voltage is on a standard over ground 3 & 4 aspect signal and the signals thats are in sideings at all?
I think you'll find that many urban signals are powered directly from the mains.
The railway does indeed prefer to use its own supply for signalling where possible, this is not actually generated by the railway but is obtained from the grid. The signalling power supply should be much more reliable than a normal grid supply since it is usual to provide either duplicate feeds from two grid areas, or a single feed and a generator.
The signalling power supply is normally distributed at a relatively high voltage, 660 or 720 volts being popular. At the point of use this is transformed down to a lower voltage, often 110 volts.
Individual bulbs in signals are usually 12 volts, as posted above, with a transformer for each bulb.
Most signal lamps have now been replaced with the infamous LED light engine conversions.
Those bloody light engines... granted, it means less work, but when they black out... oh boy
That's what we find. We do have a couple, as a trial, that have the ECR strapped out but I don't know whether we are getting funding to strap all of them out. We have had a few though where they just black out :/ usually in SSI areas
The signals where the bulb has been replaced with an LED cluster are fine because the beam is still focused by the lens, the ones where its just a cluster of LEDs (all in one aspect or seperate) are fu fu fulippin awful, they are blinding in the dark and next to useless in fog where the beam cant 'cut through'. But what do I know, I just drive past them everyday with my eyes shut in the dark and straining to see them in the fog!
As for those cheap and nasty VFM? signals, no comment!![]()
Do you mean VMS? (lightweight 'flat panel' type?) I was under the impression that 'the Southern' wouldn't have anything to do with them. They were apparently considered for the new London Bridge/Thameslink signalling but rejected in favour of a more traditional LED type (and writing 'traditional' and 'LED' together doesn't look right, they're still new-fangled to me!).
I heard the same complaints you raise, but specifically about those, ie there is so much light that with several on a gantry you cannot tell which is yours until you're more or less on top of it, especially in misty or foggy conditions.
The best ones are the LED enhanced conventional/traditional head, nice clear colours, well seperated and good penetration without blinding the drivers, which is why they will be replaced with those silly 'all in one' signals. :roll:
the colours are more defined especially the green which is very green instead of bluey green.
That seems a bit rum! Do you mean the signal isn't being proved lit in the signal in rear? I'm surprised that's been authorised, unless it's on, for instance, a terminal station platform starter with nothing reading up to it.
They're quite widespread now, I've noticed them around Manchester, on various ECML locations, and around London Bridge. I only know of the ones manufactured by Howells, are these the ones you are having trouble with?
This is because a conventional lamp gives off a yellowish light, therefore green aspect lenses are actually blue - blue and yellow makes green. The lamps were replaced with LEDs, which can display white light and would thus cause a blue aspect, so a coloured LED is used to get the right sort of green.
Do you mean the dichroic "optic diode" jobbies (as seen around Stockport-Wilmslow)? Those are more like the old searchlight types in that they show all three colours through one aperture, with a second yellow-only aperture if required.
They are a single light source with dichroic filters to make the colours.
Apologies. I think I meant the EKR
That's makes a bit more sense, however, according to the Howells website, they provide a 'dummy' ER to put in place of the original relay, to maintain the connections, although they also state that the engine itself draws enough current to energise the relay.
