- Joined
- 15 Apr 2008
- Messages
- 17,591
Gauge clearance is just something that has a cost, and one we don't tend to spend on. It doesn't mean that you are rebuilding every structure either which is often the assumption.
Driverless self-propelled sets of wagons could proceed to hubs for joining up into longer trains for the long haul to other hubs where they would split for the final trip to the destination. All this could be carried out automatically, rather like packets of data being routed between computer networks.I think we are at least ten years away from large driverless automated road vehicles, even on motorways. Although there are now small battery electric delivery robotic vehicles operating in some places around the word, including in Milton Keynes, these travel at pedestrian speed. Here is a search link to a number of videos.
Similar concepts and technology to what you describe could be used for other transport systems though. Including rail. Arrive at the "transshipment" location. Detach your purpose designed trailer or wait for the fully automated robotic system to unload your module (most likely very similar to existing standard containers). Electronically confirm the details via your internet connected pad. Leave. Then the fully automated robotic system can assemble a multimode train. Once ready, said train will receive a final safety check from the depot staff. Then the driverless ERTMS fitted automated train will depart.
It will then travel to the next required "transshipment" location where items will either be loaded or unloaded or both. Again, the changes will be by a fully automated robotic system. After a final safety check from the depot staff, the train will continue it's journey.
The train will be in continuous contact via radio communications so that the control centre both knows it's location and so a human can amend or adjust anything if needed.
How competitive this could be compared to road transport I don't know. And obviously a substantial upfront investment would be needed for both the train and the "transshipment" locations. Also, it would only be economic to use existing railway lines, which limits the areas where this service could be offered. But if running costs are lower than running a conventional road distribution system, it may happen at some point in the future.
That's what we used to call 'trip workings' and 'marshalling yards', albeit it under human control. Previous posters have said how inefficient that was but could computer algorithms make it more efficient and doing away with the biological interface between the signalling system and traction controls reduce operating costs enough? I don't know.Driverless self-propelled sets of wagons could proceed to hubs for joining up into longer trains for the long haul to other hubs where they would split for the final trip to the destination. All this could be carried out automatically, rather like packets of data being routed between computer networks.
But if your paths are in an easily accessible location you don't need to impact passenger trains as severely as you suggest. Especially if your yard feeds into a line that's having a relief line built for the busiest 100 miles. The critical constraint on Wembley Yard would be North London Line paths, which is harder to resolve.You still need paths for it all however you process it in London. That means less paths for passenger trains.
Any cost will not help railfreight compete with road haulage. Although yes, on many routes there are many structures that would already be clear, especially on routes that are being electrified.Gauge clearance is just something that has a cost, and one we don't tend to spend on. It doesn't mean that you are rebuilding every structure either which is often the assumption.
Railfreight wouldn't be paying for it though, NR would be.But if your paths are in an easily accessible location you don't need to impact passenger trains as severely as you suggest. Especially if your yard feeds into a line that's having a relief line built for the busiest 100 miles. The critical constraint on Wembley Yard would be North London Line paths, which is harder to resolve.
The problem is that you need your marshalling "yard" to actually stretch over a wide area of delivery and pick-up locations, not just a place to chop and change two freight trains into two different freight trains - that can be done quite happily with a crane. Self driving lorries in controlled environments would be a pretty niche solution.That's what we used to call 'trip workings' and 'marshalling yards', albeit it under human control. Previous posters have said how inefficient that was but could computer algorithms make it more efficient and doing away with the biological interface between the signalling system and traction controls reduce operating costs enough? I don't know.
Neither is Cargobeamer (using standard road trailers) possible within the UK due to the same loading gauge problem.You could probably do something using the technology being pushed by "CargoBeamer".
Basically park your lorry trailer or other load on a tray and then it gets shunted sideways on and off trains etc.
Obviously proper TOFC/Rolling Highway operations are not possible in the UK due to our terrible loading gauge.
You could put a container on a Cargobeamer style sled.Neither is Cargobeamer (using standard road trailers) possible within the UK due to the same loading gauge problem.
It was about the most useful example of a centralised road haulage system I could think of. The improvement is not needing a driver and their time limits for the long distance parts & given it's a known set of routes, you can optimise things like overhead wire charging sections & whatever, and you're also not having to pay a driver if a tractor unit has to run somewhere without a load. The human drivers run the customer ends which need much more flexibility & someone to check the load for safety etc ( and do the admin signoffs ), which is not something that'll ever be fully automated anyway, I think. We're just about there with car autopilots on the motorway already technology-wise, regulatory & so on is a bit of a different story.Doesn't really offer much improvement on what happens today.
The likes of Stobart or Wincanton have far more trailers than tractor units. What they'll tend to do is drop a trailer at its destination and pick up one for return either from the customer they've just delivered to (who may be moving pallets or roll cages around as well as full loads) or a different customer.
What do you use to put the container on the sled.......a reachstacker, which is already on site loading and unloading HGVs, putting containers to stacks etc(something you can't do with HGV trailers), and loading trains. You have simply added another level of complexity and capital equipment cost to an existing system.You could put a container on a Cargobeamer style sled.
The point being automated container movement, given lift costs are the expensive part of operating an intermodal terminal.
You could build a system like that to move sleds between trains etc.
I disagree. At the moment this technology is classed as a driver aid / driver assistance. It’s a significant difference compared to a fully autonomous vehicle that has absolutely no real time (live) monitoring by a human.We're just about there with car autopilots on the motorway already technology-wise, regulatory & so on is a bit of a different story.
Is it even permitted to sell something as an autopilot? legally you probably have to be fully in control of the vehicle at all times ( I didn't look that up, that's just guessing ), definitely not really any regulatory framework to support autonomy right now. I think the technology required to perform the tasks is there, the robustness I doubt ( and after spending a good 30% of my life in software, autonomous anything does not make me relax in any wayI disagree. At the moment this technology is classed as a driver aid / driver assistance. It’s a significant difference compared to a fully autonomous vehicle that has absolutely no real time (live) monitoring by a human.
Cargobeamer may have a place in carrying standard road trailers but applying it to containers is a technology too far. The attached video shows the complexity of the system. The fact that the technology is duplicated at every rail wagon position and even the rail wagons have additional complexities means that you will employ more mechanics than I will reachstacker drivers. Speedier trans-shipment, if needed at all in the confines of the UK, can be achieved by selective portion swapping of rail wagons.And where will all your personnel to operate these reachstackers come from?
How will you pay for all the demurrage for trains sitting around in yards whilst reach stackers remove containers one at a time, or load containers one at a time?
If you want container shipping by rail to be anything but a tiny niche, you need to be able to sort containers between trains rapidly and with the minimum of labour required.
Asking for capital spending when it will reduce ongoing costs is one thing, but if your ongoing costs are hopelessly uneconomic it doesn't matter how little capital spending you need.
