Enviro200 lights
JasonSmart
3 Jul 2021
Fife
Hello, I wonder if anyone can advise on the layout of the front light cluster on the above vehicle (ADL Enviro200MMC). I’d like to know which is the headlight, daytime running light, side light etc.
TRAX
2 Dec 2015
France
The top one is low beam, the middle one is DRL/parking + blinker, and the bottom one is high beam.
JasonSmart
3 Jul 2021
Fife
Hello!
I previously posted a question about the light cluster layout for Enviro 200 buses.
I was given the information that the middle of the 3 lights on the front was for daytime running lights and also the side/parking lights.
I wonder if someone could tell.me how it would be visible the side lights were on rather than the daytime running lights?
Also, what is the layout of the lights on the rear?
Thanks in advance
90019
29 May 2008
The sidelight is a single LED in the centre which isn't especially visible on its own. The indicator is most of the rest of the unit with the DRL being a 1 LED wide ring around the outer edge.
Rear lights depend on what they've been specced with, but generally the upper light is the tail, brake and indicator while the lower is either combined fog and reverse or one of each on their respective sides.
JasonSmart
3 Jul 2021
Fife
So a bus that is being driven that has the outer ring plus a single Led in the centre this would be the daytime running lights or drl with sidelights, and the sidelights on would just show the single Led?
90019
29 May 2008
Luckily I'm driving an Enviro with those lights this evening.
Daytime running light only.
Daytime running light plus sidelight.
Sidelight plus headlight (DRL off)
Daytime running light, sidelight and indicator.
JasonSmart
3 Jul 2021
Fife
Thanks for that info. I take it it's quite common for these to be driven with sidelights during daytime hours as well as drl?
