Eurostar Business Premier?
GodAtum
11 Dec 2009
Is Business Premier worth it to have fast track? there always seems a massive queue at St Pancras or Standard passengers, but the Business premier is empty!
Mag_seven
1 Sep 2014
here to eternity
I think that once you are through security you have access to a separate lounge so that may be worth the extra money?
colinz
21 Mar 2015
The lounge can also be accessed with an AmEx Platinum card, which I believe could potentially work out to be cheaper than buying Business Premier if you make multiple journeys.
dutchflyer
17 Oct 2013
It should be there at any of its 3 terminuses, thus also BRUssel, incl lounges.
But now that there is also again passport check @ LOndon-would British immigration (or whatever you name it this year) also comply?
anme
8 Aug 2013
There is not always a massive queue for standard class passengers. It depends on the day and time, and how many trains are open for check in. Sometimes you can walk straight through. In any case, as long as you arrive within the advertised check in time requirements, you will get on your train,
Business Premier is usually much more expensive that standard. It would not normally be worth it for the check in time saving. Anyway, there's not much to do after check in at St Pancras.
paddington
19 Feb 2013
I'm always in Eurostar Standard. At St Pancras I always go to the rightmost lane. More often than not, the staff direct me to the Business Premier security queue as it is empty.
anme
8 Aug 2013
How can I see what seats are available before paying?
Do you mean what seats on the train? As far as I know you can only see what seats are available after you have paid. The Eurostar call centre might be able to help.
Why do you want to?
GodAtum
11 Dec 2009
Why do you want to?
I'd like to get 2 seats next to each other.
AlexNL
19 Dec 2014
If you book two seats at the same time it's very likely that both of you will end up next to or opposite of eachother. And otherwise, you can immediately change your seats after booking.
A few months ago I booked tickets for 8 people, we all ended up close to eachother and nobody had to sit alone.
S-Car-Go
19 Mar 2019
Depends on how much you value the benefits (lounge access [free bar/snacks], refundable tickets, short queue, big seat, meal & drinks).
The normal St Pancras queue can vary a lot. Generally...
Busy: Mon am, Thu pm, Fri pm, Sat am, Sun pm. Not including start of school hols, bank hols, sporting events, disruption, air traffic control issues etc.
