Examples of non-UK rail services run primarily/wholly for leisure travellers?
notlob.divad
19 Jan 2016
Bit of a different form of 'Leisure' travel
PKP Polish National railways have, (when the festival has been running) put on special trains from Kraków and Warsaw to Gdynia for the Open'er Music festival. In some cases artists who will play at the festival have also played officially sanctioned Micro gigs on the train as it is travelling.
The narrow gauge Circumetnea on Sicily is certainly a sightseeing line, but it is also a vital local railway for the many villages en route, many poised on the edge of lava flows, some of which are quite recent (the railway itself has had to be diverted along a new alignment at times).
You travel at quite a high level on the middle section, keeping about 10km from the summit.
Not quite circular, from Catania, round Etna and then back down to the coast at Giarre/Riposto (for main line back to Catania).
Not many through journeys, usually changing 2/3 of the way at Randazzo, the main railway depot for the line.
If you don't stop over anywhere, the circular trip will take about 4 hours and cost about €10.
Mix of old and new (Polish) DMUs on the narrow gauge line.
Clockwise, Etna is permanently on the right, usually trailing a plume of smoke.
Fine views west and north on the left side.
You have to use the metro from Centrale to reach the starting station at Catania Borgo.
Cheshire Scot
24 Jul 2020
North East Cheshire
Glacier Express and (perhaps to a lesser extent) Bernina Express
Plenty of other trains on both of these routes albeit involving a change of trains but the bulk of the passengers on the above are likely to be tourists - including no doubt some Swiss nationals enjoying the scenery of their country. .
Train jaune
20 Nov 2011
Lancaster
You defo need to do the old stock, particularly the open wagons if they are still running. The temperature change as you climb up towards the top is disconcerting, I was sweltering when I boarded but freezing at the top wishing I'd brought my jumper
43096
23 Nov 2015
The Rhätische Bahn have run plenty of services aimed at tourists over the years: the various workings with the “Krokodils” on open stock, the annual toboggan trains taking tobogganists up the Albula line and the weekend Landquart/Chur-Ilanz trains all spring to mind.
davetheguard
10 Apr 2013
In the German state of Thuringen, the Sud Thuringen Bahn operate a service of four return trips a day at weekends through from from the state capital Erfurt over the line from Ilmenau to the station at Rennsteig located high in the forested hills of the region. The line normally has no scheduled service beyond Ilmenau, although a railway preservation society seem to be based at Rennsteig station too. En route, the train also serves the normally closed stations of Ilmenau Bad and Stuetzerbach.
To travel on the train, you need to buy a special "Rennsteig Shuttle" ticket from the ticket machine on the train itself, although on the day we did it, there was also a Conductor on the train selling the tickets too. The Rennsteig is a German long distance footpath, and the train service is run primarily for walkers & tourists.
  • 154. Two bubble cars at Rennsteig station on the 10.37 Rennsteig Shuttle to Erfurt..JPG
Cloud Strife
25 Feb 2014
Yes, same with PolRegio running trains to Woodstock/Pol'and'Rock.
Gloster
4 Sep 2020
Up the creek
Danish State Railways usually put up a special halt on the Roskilde-Køge line for the Roskilde Festival. Shuttles from Roskilde or Copenhagen, or special trains run.
DanielB
27 Feb 2020
Amersfoort, NL
In a similar setup, The Netherlands has also got four stations only served in case of events (Rotterdam Stadion, Amsterdam ArenA, Eindhoven Stadion and Heerenveen IJsstadion). Although only the first one gets some sort of regular service on matchdays and with events, the others are rarely used.
A special one from the past was "Onze Lieve Vrouwe ter Nood" halt, serving pilgrims visiting the nearby monastery. It was served only a few times per year, by regular trains, and only had grass covered pile of dirt as platform. Unfortunately the halt was closed following a safety incident with pilgrims walking along the tracks after being stranded on the platform, which they couldn't exit as a newly build fence didn't have a door in it.
There has also been a sixt event station in The Netherlands, Almere Strand, which was served once a year serving visitors to the yearly fair of a Dutch magazine. This one also closed in the mean time as the expansion of Almere led to the construction of a new permanent station nearby.
52290
23 Oct 2015
Steam is used on the Historical Train between Régua and Pocinho.
Unless you've travelled on that train back when the company couldn't care less and used ICE Diesel exclusively (this was somewhat between 2010 and 2015).
Currently that train uses the same steam locomotive it traditionally relied on, with the catch that the firebox was adapted to burn diesel.
When I use to travel on the Douro line east of Regua in the late 60's and early 70's only certain types of steam loco were allowed due to weight restrictions on the bridges. In common with most other CP broad guage steam locos they were oil fired. One exception to this was No 014, a Beyer-Peacock coal-fired 0-6-2 tank, which was kept at Pocinho for banking trains up from Freixo de Numâo. I suspect that today's tourist trains have motive power different from those days now the bridges have been strengthened.
52290
23 Oct 2015
2-8-4 Henschel & Sohn tender locomotive, Nr. CP 0186. That class used to be pictured at Régua.
The 2-8-4T 's along with the 7xx 2-8-0's got as far as Regua but were not allowed any further East along the Douro valley.
miklcct
2 May 2021
Cricklewood
Disneyland Resort Line in Hong Kong MTR - an exclusive branch railway connecting the Disneyland to a main commuter line.
superalbs
Verified Rep - Superalbs Travels
3 Jul 2014
Exeter
The RegioJet trains to Croatia! They're seasonal, and I can't imagine have many business travellers on the noisy and delayed ride to Split!
nanstallon
18 Dec 2015
I'm not sure whether it still runs, but suspect that the once daily train from Neussargues (originating in Cermont-Ferrand) to St Chely d'Apcher and on to Millau and Beziers carries mainly people out for the ride, especially over the Garabit viaduct. Long may it continue to run!
I remember in 1971 taking a photo of a 7xx 2-8-0 coming into Tua on a freight.
30907
I suspect it doesn't, sadly, apart from enthusiasts!
In the mid-90s the local tourist board put on a circular tour from Millau covering the Cevennes and Causses lines - I enjoyed a splendid day in a new DMU (X72500 I think - I was the only non native French speaker) - but it lasted at most 2 seasons.
Seconded!
