It seems an FCC train has left it's pantograph up at Blackfriars, and as a result, it has clipped the ceiling above the line.... Southbound lines have been closed for at least an hour now. How can this happen?! (There are pictures on twitter)
No springs in that pantograph.
Air pressure is used to keep the pan' up on a 319.
Oh wonderful.
That's my evening commute stuffed then
All cleared now
Not completely wrong though. Some 319's do ave em (stone faiverly pantographs)
Pretty sure its a brecknell willis which uses an actuator
The person that Tweeted the photo and has now had Metro asking for permission to use the photo has suggested it was a cock up by FirstCC. Interestingly, FCC didn't reply to confirm or deny the fact.
However, if it was a train fault I do wonder if the person who Tweeted, and indeed the journalist that writes any story in Metro, will apologise? A large number of people have re-tweeted or favourited the photo and will probably be holding the driver and FCC as responsible.
I'm surprised there isn't an interlock that prevents drawing from the Third Rail while the Pantograph is raised.
There is, isn't there? Otherwise there would have been quite a nice bang as the pan went live and earthed against the roof
If it is indeed a train fault -who is ultimately responsible?
(I'm not suggesting all technical faults are practically preventable however if the train was serviced every 5mins all technical faults would be less likely.
Someone somewhere has drawn a line somewhere and decided how often potential problems should be checked for)
Why would it be needed? At stations like farringdon and Drayton park you need to be able to draw from both shoes and pan to leave the station as when you put the pan up the shoes are still on the 3rd rail. An alarm goes off in the cab to warn you however.
To be fair, even if it was driver error then the driver dosnt deserve the comments they are getting on twitter and in the press. It wasn't deliberate and it wasn't incompetence. It would be exactly the same as any other operational incident. I'm not speculating what happened but putting the pan up is just a case of pressing the wrong button without thinking-no different to opening the doors the wrong side or stopping at a red signal away from a station and opening the doors.
You can be sure that whatever the truth, the anti-FCC brigade will be adding this to their list of reasons why FCC are crap and should be stripped of the franchise etc.
Metro has written: "The apparatus seems to have not been lowered at Farringdon station before it went straight into the ceiling at Blackfriars station on Thursday morning."
Which is stupid. It's bloody obvious it wasn't lowered as you only need to look at the photo. How dumb to try and be vague on this, yet not mention anywhere that it's not clear if it was a train fault or driver error.
All it means is that people will jump to one conclusion - driver error. Case closed...
Meanwhile London24 has gone with:
"The First Capital Connect service blocked the southbound lane after the driver raised the pantograph and hit the ceiling."
So definitely the driver at fault from their detailed investigation.
Only the BBC actually saw fit to write:
"It is not yet known how the carriage's pantograph - which connects the train to the overhead lines - came to hit the roof of the central London station."
Maybe the BBC should have asked Kate Nelson at London24! She obviously has the inside scoop.
The BBC look like the only Media who have written a story based on the facts, though referring it as a "crash" is a bit over dramatic. Collision seems more appropriate.
Neither, it's a strike.
Crash, haha.
