Finland "plans to" change to standard gauge
The exile
31 Mar 2010
Somerset
The Germans certainly had lots of mechanised and motorised units but they also marched into Russia with hundreds of thousands of horses. You don't get to Blitzkrieg without tanks and motorised transport but a lot of German logistics relied on the good old fashioned horse.
And the good old slightly less old fashioned railway. The initial Blitzkrieg advance was “road borne” but you can’t out-run your supply lines for very long and that’s where trains came n (and, tbh, probably still would)
Meerkat
14 Jul 2018
The Russian military has huge railway resources. As the structures would allow the wider gauge they would just change it back.
You could achieve similar delaying Results by not spending the money on gauge changing and instead buying some rail ploughs and prepping demolition points on every bridge (would be surprised if these weren’t already Finnish policy).
Yes I think that's the thing to understand. The Russian military relies on railways and they have the equipment and units to match. They have dedicated railway brigades dedicated to operating, building, maintaining and rehabilitating railways. They take this stuff seriously. Far more so than any NATO nation does. Regauging the track to standard gauge will make it much harder for the Russians (and much harder than it would be to just say relay a few miles of track) but in reality if you want to stop them from using railways for any particularly long period of time you need to rip out as much track (of any gauge) as possible as you go, and demolish overbridges, viaducts and everything else as well.
Otherwise they'll just either relay a few miles and hook back into the remaining Russian gauge network or they'll set too at regauging all the track that you've converted.
It remains a barmy idea though. You'd be better investing a fraction of the money in making sure that there are solid plans in place to render as much of the network as possible unusable as you retreat.
JonasB
27 Dec 2016
Sweden
Do rail ploughs work on concrete sleepers?
Meerkat
14 Jul 2018
Good question - the fixings might give way first?? That would still make a mess.
probably best we don’t discuss the best ways to wreck a railway in much detail!
superalbs
Verified Rep - Superalbs Travels
3 Jul 2014
Exeter
What's a rail plough?
No, that sign means the speed limit is 40 km/h. Finnish speed signs uses tens of kilometres per hour.
As is common in most of central Europe, certainly in Germany, Austria and Poland.
They don't have line speeds ending in "5" km/h.
DanielB
27 Feb 2020
Amersfoort, NL
Though also the latter isn't impossible. The Netherlands has also speed signs with decimals, but those are rare.
For example at a train washing machine you'd find a speed limit of 5 km/h which is indicated by a speed sign with a zero and a 5 in superscript.
MarcVD
23 Aug 2016
Same in Belgium.
AndrewE
9 Nov 2015
Yes lots of bonus gauges in a setup like that. Untill you get to points. I'm surprised the rails aren't a bit closer.
maybe the separation is so that the frogs and crossings can be fitted in?
AdamWW
6 Nov 2012
Possibly. I thought when I'd seen pictures of similar dual gauge before they were closer but could have imagined it.
jamesontheroad
24 Jan 2009
Short answer yes. Most motorway overpasses in strategic parts of Finland are designed for very rapid demolition in the case of invasion.
