I also think the role has slightly changed now as depot drivers can now drive between Bedford station/sidings and Cauldwell depot.
If you have passed all the mainline trainee driver assessments with FCC but are waiting for a position, would you have to sit the psychometric tests for this position does anybody know? Cheers
Do you have the chance to progress to mainline or are you stuck on the depot.
The standards for psychometric tests are exactly the same for both depot drivers and mainline drivers. There is no difference.
If you do get the job as a Depot Driver, don't automatically assume the grass is greener on the mainline. Do your research and weigh up the pros and cons before considering making a move. In some TOC's, the Depot Driver role is a decent seperate role in itself, and is not simply a stepping stone to mainline.
I believe it's so you can get to the depot quickly and easily if needs be.Quick (and probably fairly obvious) question: Why is a full UK Driving License necessary? Surely the similarities between driving a train and a car are pretty minute?
Can anyone confirm which tests / interviews FCC uses?
Thanks. No reactions or memory test?
I'm sure this vacancy had a closing date of 1.4.13 but it's gone from the First vacancy page today
Far as I know they've filled the vacancies.
Especially Depot Driving - which has even less similarities to driving a car than mainline driving.Quick (and probably fairly obvious) question: Why is a full UK Driving License necessary? Surely the similarities between driving a train and a car are pretty minute?
