First Rail Stirling (Lumo) Rolling Stock
Driver068
20 Feb 2014
Apologies if I've missed something however don't the 222s only come in 5 and 7 car formations. Is their already 6 car formations or are Alstom/Lumo discussed this as past of their contract.
How would it work, adding 1x car to a 5 or reducing a 7 to a 6
22x have largely independent vehicles so can be reformed in this way.
There are 4 7-car units. Vehicles will be removed from these and inserted into 5s giving twice as many 6s (not sure if ScotRail will also take a few 6s given that Lumo only want 5 of them).
QSK19
29 Dec 2020
Leicestershire
Which makes one wonder what is happening with the 3 surplus cars from the 7-car units? Only one of them would be needed given that a single lengthened 5-car unit effectively makes up the five strong 6-car 222 contingent moving across to Lumo.
Can’t really think that EMR will want to lengthen 3 of their existing units to 6-car operation given they want to standardise the unit size ahead of 810 introduction. Putting the 3 surplus cars into storage would presumably save a few quid on leasing and diesel costs too?
InvHst
9 Dec 2018
Here's a question where are all these sets when they enter service going to be stored. I know they will be able to store one in Preston for the extra service. But what about Stirling and London where will these sets be stored?
nolypops83
13 Feb 2023
Manchester
Wembley would make sense for London Euston.
BlueLeanie
21 Jul 2023
Haddenham
Scotrail currently stable vehicles at Stirling, Not sure if there is any spare capacity for Lumo. Any capacity at Perth?
Did LNER stable their former 05:xx service overnight at Stirling?
dan4291
9 Dec 2019
County Durham
Could Craigentinny be a possible option? Cross Country stable some Voyager sets there overnight so the mechanically similar 222s would make sense, and Lumo also use that depot currently for their Hitachi units. It would obviously mean an ECS path or two from Craigentinny to Stirling, plus the route learning requirements to go with it.
Devon Sunset
20 Oct 2020
East Lothian
I heard an enquiry has been made about Cadder but only a rumour at this stage
800001
24 Oct 2015
Craigentinny is more or less full each night.
What about Eastfields for the Stirling? Or even Millerhill.
As it is suggested that the other 222s are going to Scotland, there will, in time, be other 222s being looked after in Scotland, but it doesn't seem obvious that an open access operator can use the facilities of a depot current run in house by a TOC.
I don't think Polmadie now sees diesel stock (other than its shunter) but given it is an Alstom depot, seems the obvious location for a Stirling terminator if Alstom are contracted elsewhere.
43096
23 Nov 2015
Polmadie would be more likely as it is Alstom depot.
Helvellyn
28 Aug 2009
Wonder which units will go. A tidy solution would be the four 222/1s plus 222023 (to become 222105), reducing 222001-004 to 5-cars. Would leave 222001-022 to move to ScotRail.
Would at least standardise the EMR 222 fleet to two internal layouts until the 810s are introduced.
QSK19
29 Dec 2020
Leicestershire
Sounds like a practical solution, though in order to avoid moving more cars around beyond the minimum number of moves required, couldn’t they just renumber 222001-222004 to 222101-222104 and vice versa? Would mean not having to reconfigure the existing 222/1s - simply renumber them to 222/0.
They would then, as you say, put an additional car into 222023 and renumber it to 222105.
D365
29 Jun 2012
The /1 subclass is because those four units [in their original 4 car formation] were procured and delivered separately to First Hull Trains. There are minor part differences to the /0 but, as evidenced by their current use, the two subfleets are fully compatible.
It may end up being that the 4 off /1 units are transferred to Lumo, plus 1 off /0 unit. But this doesn’t necessarily have to be the case, and there certainly isn’t any need to renumber units unnecessarily.
QSK19
29 Dec 2020
Leicestershire
Yep, and renumbering is admittedly quite minor in the grand scheme of things. Lumo will be getting 5 of them regardless of which ones and, given the slow progress on the 810s, EMR will most likely have to work with a fleet of 22.
liamf656
2 Aug 2020
Derby
That's actually more of a faff than just reducing 001-004 to 6 car and inserting a coach in a 5 car to create the five units Lumo require, then all remaining units can move to wherever they're destined for quite easily
Driver068
20 Feb 2014
Cheers for the information.
Not wanting to go off topic so just a quick quesgion, if lumo are acquiring 222s who else are looking for them as GC seem to be in the mix...can not be that many to go around is there?
There’s a few threads about a number of 222 possibilities, but realistically it’s Scotrail to replace their HSTs.
D365
29 Jun 2012
Grand Central has announced 9 Hitachi AT300s to replace the Class 180s [and 221s].
Bob Price
8 Aug 2019
There was talk about a South Wales to Liverpool service using them but that is just proposed at the moment.
Wyrleybart
29 Mar 2020
South Staffordshire
And 180s to be used on the Newcastle to Brighton service of it does get the go ahead.
And Cleethorpes too !!!
Not sure the nine AT300s will cover all of GCRs stated aspirations.
Under the current class 180 fleet I think they need a minimum of seven units to cover all the current diagrams, and they can only use the two 221s on two of the Bradford diagrams, assuming both are available, this not allowing for any Kings Cross swaps between the Sunderland and West Ridings services, which are designed to get "fresh" 180s from Crofton onto the Sunderland route.
As for 180s to Brighton - hmmm !! Theoretically 221s are route cleared all the way to Brighton from their XC service pre 2008, although the former Brighton XC crews dispersed to all companies and other train crew depots.
