13MAY
Changes to routes and timetables from 16th May 2021
We’re introducing several new services and running more buses on many routes from Sunday 16 May 2021.
TImetables can be viewed here >>>
The following routes are changing number, please see the new route for details of the change:
A1, A2 & A3 are now the new Land’s End Coaster
A4 & A5 are now the new Atlantic Coaster
A17 is replaced by new 17, 18 & 19
L1 between Helston and Truro is replaced by new L3
Atlantic Coaster is the new name for the A4 and A5 routes. It will run along the coast between St Ives, Hayle, St Agnes, Perranporth, Newquay, Watergate Bay, St Merryn and Padstow. The route remains the same except in Newquay, where buses for St Ives and Newquay will serve Treloggan Road and Newquay Zoo in both directions.
Daytripper is a new network of routes linking mid-Cornwall and the Eden Project (see below for more details). This includes the
D5 which runs up to hourly between St Austell rail station, Carclaze, Trethurgy and the Eden Project.
Buses take you straight there and they also offer connections to onward destinations such as Charlestown, The Lost Gardens of Heligan, Lanhydrock and Polperro amongst others. This is a quick summary of places served on each route:
D1 Newquay, Porth, St Columb Minor to Eden Project
D2 Holywell Bay, Crantock, Quintrell Downs to Eden Project
D3 Perranporth, Mitchell to Eden Project
D4 Truro, Tresillian, Probus, Grampound to Eden Project
D5 Mevagissey, St Austell rail station to Eden Project
D6 Eden Project to Lost Gardens of Heligan
D7 Eden Project to Charlestown
D8 Fowey to Eden Project
D9 Looe, Pelynt, Lostwithiel to Eden Project
D10 Eden Project to Lanhydrock
D11 Eden Project to Padstow
Falmouth Coaster is a new route that runs around Falmouth, Pendennis Point and Swanpool Beach.
Land’s End Coaster is the new name for the previous A1, A2 and A3 routes. The route remains the same except that buses will not go into Botallack village and buses will stop on the main road instead.
L1 will run more frequently between Helston and Lizard village. The route will change in Helston – buses will start from Coinagehall Street opposite The Blue Anchor and travel uphill to serve Tesco and Sainsbury’s before heading to Lizard. Towards Helston, buses run direct from Sainsbury’s to Coinagehall Street opposite The Blue Anchor via Meneage Road and Whitehill Terrace. The route will also change as it approaches Lizard – buses will serve Kuggar towards Lizard and you’re able to travel via Lizard to reach Helston. The new L3 will replace the L1 between Helston and Truro. Buses are timed to connect at Helston with the L3, L5 and U4.
L3 is a new route that replaces the L1 between Helston and Truro. Buses start from Coinagehall Street opposite The Blue Anchor in Helston and travel uphill to serve Tesco before heading direct to Carnon Downs then Truro. From Truro, buses run direct from Carnon Downs to Helston Tesco, then run via Sainsbury’s, Meneage Road and Whitehill Terrace to Coinagehall Street opposite The Blue Anchor. Buses are timed to connect in Helston with the L1, L5 and U4.
L5 is a new route between Helston, Hayle and St Ives. It also runs via St Ives Holiday Village in the morning towards Helston and in the afternoon from Helston. Buses are timed to connect in Helston with the L1, L3 and U4.
M6 has a revised timetable. Buses run up to every 20 minutes Mondays to Saturdays end every 30 minutes on Sundays.
S1 is a new route between Dairyland and Newquay.
This starts from Saturday 29 May 2021.
S2 is a new route between Trevarrian and Newquay.
S3 is a new route between RAF St Mawgan and Newquay.
Tinner T1 & T2 have revised timetables, with buses running more frequently during the daytime.
U1 & U2 have revised timetables, with buses running up to 5 minutes earlier or later than present.
U3 will not change but be aware that this service will only run until Friday 28 May when the university term ends.
U4 has a revised timetable, with buses running up to 5 minutes earlier or later than present during the day. In the early mornings and late evenings buses run to a new timetable with the first buses starting in Helston and the last buses finishing in Helston. On Sundays, buses will now run hourly.
17 is a new route that replaces the A17 between St Ives and Penzance. The timetable has been amended and some buses are running earlier or later than present. Between Penzance and Pendeen, buses will be renumbered 18 and between Penzance and Madron, buses will be renumbered 19. As today, most buses from St Ives will continue through Penzance town centre – please advise your driver if you’d like to stay on the bus.
18 is a new service that replaces the A17 between Pendeen and Penzance. The timetable has been amended and some buses are running earlier or later than present. Also, on Sundays, buses will run hourly and continue to serve Madron. As today, most buses from Pendeen will continue through Penzance towards Tesco and Long Rock – please advise your driver if you’d like to stay on the bus.
19 A new service that replaces the A17 between Madron and Penzance. The timetable has been amended and some buses are running earlier or later than present. On Sundays, the 18 will run hourly and also serve Madron. As today, most buses from Madron will continue through Penzance towards Tesco and Long Rock – please advise your driver if you’d like to stay on the bus.
24 – No change
27 – No change
86 A new service that runs parallel to the current 87 in part. The route runs from Truro via the Royal Cornwall Hospital (Trelawny Wing) at Treliske, Threemilestone then direct to Perranporth. From Perranporth, the 86 will then serve Perran Sands Holiday Park, Goonhavern, Holywell Bay and Crantock towards Newquay, following the same route that the 87 serves in the evenings.
87 has a revised timetable and buses run earlier or later than present. Buses on the 87 will serve Perran Sands Holiday Park when the 86 is not running On Sundays, the 86 will now serve Holywell Bay and Crantock during the daytime.
91 has a revised timetable and buses run earlier or later than present.
atlantic coaster leaflet WEB.pdf
lands end coaster leaflet WEB.pdf
lizard leaflet WEB.pdf
falmouth coaster leaflet WEB.pdf
daytripper WEB.pdf
