freetoview33
Has anything old gone as a result? Or just additional buses for all these changes
Are all of Bristols latest Streetlights now in service?
Hi There,
Noted at Taunton today were 34092/098 at Bus Station and 34219 at the Depot, 3 ex Manchester area Olympians presumed en route [lay-over] for Devon/Cornwall operations.
Also 66745 has returned here in green livery minus fleetnumbers and vinyls at the moment.
Cheers, Mike Russell [henairs]
I don't think that many are needed anyway, there's no increase for the 82 as in the time currently sat at Chipping Sodbury it gets up to Wotton and back, think the 83 is an extra bus, the 87 is 2, and the 88 looks to be the same bus off peak but 2 at peak.
Illuminating stuff this - I think you mean Streetlites.
Interesting to observe 47563 out on the 49 this afternoon
Is 47563 a Lawrence Hill bus then?
Really not a good evening for the 70/71 today. 42115 left UWE on the 70 at about 1725, which is already bad enlugh for the peak hours, then there was no 70 OR 71 until 1750. 69459 arrived on the 72 which was by this point absolutely rammed upon departure. 42737 (even worse!) then turned up on another 70, then 32332 on the 71 just turned to Not In Service!
Not great that they were all singles on the route, they're just too small for such services.
What happened to First putting out deckers on the UWE routes? Didn't last long.
To be fair they're more than likely caught up in the chaos down at Temple Gate thanks to Bristol Water!
Anyone know where these Olympian's are? I have not seen them in Cornwall yet.
That depends on where you live in Yate. The X46 is diverted as well. :cry:
I travelled on the 1517 X46 from Bristol today. It was only 6 minutes late arriving at my stop in north Yate. Later journeys will probably be subject to much longer delays though.
Interesting to see that 32006 which was on the X46 this morning has found its way onto the 1447 46 departure from the bus station. Unfortunately it left about 20 minutes late so there'll be a lot of unhappy passengers by the time this bus has negotiated the diversion several times.
No. I travelled on the 1517 X46 from the bus station today which is also diverted. The first stop was "The Crown" at Hambrook though it took a little longer to get there than usual.
Only northbound. Southbound journeys are operating as normal.
Plymouth being MOT'd for Cornwall
I really think at the moment First are running a make do service because of the temple gate roadworks, I think that's why Hengrove buses have been on Lawrence Hill routes ect.
I travelled into Bristol on 32006 on Monday afternoon on the X46. It was meant to depart my stop in Yate at around 1320 but instead it arrived closer to 1350. I had an appointment to get to so didn't see it going on the 46. I was still on the 46 later on in the day when I saw it again in Yate.
According to Steve White's site, 32006/7/291 have noẃ been swapped with 66162/7/78. So MH have lost three double deckers. :cry:
On what routes do MH use double deckers apart from X46, 47 and X47?
Apart from the X7 (obviously), can't think what else MH use deckers on.
Also see ex Berkshire Dart 40956 didn't last long at HE. Delicensed already!
Just looking at those changes on Steve White's website. Seems quite interesting. They seem to be bunching all the B10s into MH (probably to replace, hence the reason why I said MH would get new buses) and bunching all the 320** range in LH (the only other one not in LH is 32001 in Weston) - could this be to replace these as well. LH only have 7 B10s now. It would be nice to see them swap these B10s for either Darts or odd deckers from MH. The depots would look much better then, but what's the likelihood of that happening!
Or the fact that the City services need deckers and an easy way to get them is move 3 across from MH. Not that it makes much difference as LH and MH buses appear on the others routes frequently anyway.
That's very interesting news about the X6. What's Weston getting in return. If the X6 is moving, does it mean that Bristol finally have E400s?
Strange, I always really thought X6 as a Bristol service. I still don't know how it is operated at the moment. Anyone care to shed some light?
