martyjon
Thanks.The majority appear to still be at Avonmouth along with at least one of the red ones.
It is a joke up Gloucester Road! Such poor timing!
A quick look at the timetable suggests that it's intended to be about as good as you'd expect from 4 different services on different frequencies. As long as the drivers are departing on time (and this is rarely an issue now with tracking) First cant do anything else other than the usual of adding a few minutes into the timetable to slow it down with the subsequent complaints that, on days when some idiot hasn't left a car in a stupid place and the traffic is flowing, the driver has to keep stopping to keep back to time.You are correct. The timing of services up and down Gloucester Road now is a joke. It's been noticeably bad since the September changes. Seems to be often three services(usually 71, 73 & 75) come along together, then it's about a 10 minute gap till a 76, and then a gap of another 10 minutes till the 71, 73 & 75, and so on. And can be even worst when services are cancelled or delayed. I had a 17 minute wait for a bus from Haymarket to Zetland Road Junction on a weekday early afternoon a few weeks ago! It's dreadfully bad, it really is. And not sure even First are aware just how bad it is nowadays. I will email them to comment about it, the services need to be spaced out more. Several years ago I emailed them to comment about the timetabling of the 70 and 73 along Filton Avenue heading towards Centre as the timetabling in the evenings was ridiculous, as it was something like the 70 and xx:00 and xx:30 and the 73 at xx:02 and xx:32! And that they should be spaced out more. They did actually take notice of this and change the timetables of these services at the next service changes.
Before the cut the 71 on evenings and sundays the 71/3 used to be about 2 mins apart. No wonder no one used the 71 as it was always just behind the 73!You are correct. The timing of services up and down Gloucester Road now is a joke. It's been noticeably bad since the September changes. Seems to be often three services(usually 71, 73 & 75) come along together, then it's about a 10 minute gap till a 76, and then a gap of another 10 minutes till the 71, 73 & 75, and so on. And can be even worst when services are cancelled or delayed. I had a 17 minute wait for a bus from Haymarket to Zetland Road Junction on a weekday early afternoon a few weeks ago! It's dreadfully bad, it really is. And not sure even First are aware just how bad it is nowadays. I will email them to comment about it, the services need to be spaced out more. Several years ago I emailed them to comment about the timetabling of the 70 and 73 along Filton Avenue heading towards Centre as the timetabling in the evenings was ridiculous, as it was something like the 70 and xx:00 and xx:30 and the 73 at xx:02 and xx:32! And that they should be spaced out more. They did actually take notice of this and change the timetables of these services at the next service changes.
Where are these 10 minute gaps? The 75 and 76 are coordinated so they run every 7/8 minutes for most of the day.The frequency of each individual service serving Gloucester Road is relatively OK. It's just across all those service together they're so poorly timetabled as a whole now. They need to be looked at and spaced out more, so there's not gaps of 10 minutes(or more) between services. It seems with the September changes they made some timetable changes to some of these services, but First didn't realise the problems this would cause with long 10 minute gaps between services, and three services being bunched up to run together! I will email about this to First, and hope things can be improved for the September changes.
A mention above about years ago(before my time!), the 5 as it was then running some shorter services to Filton Church as well as full services to Patchway Estate. Could do with a service like this running nowadays! Could also do with a half hourly service between Gloucester Road and Aztec West being re-introduced, as it's only every hour now with the T2. I know there's the 73 serving Aztec West, but that goes all over the darn place to get there!
Wonder IF or when we'll ever see a service 74 re-introduced.
Did someone say the 73 was going to be green because I just saw a photo of one and its painted green
And 39491So the spares are:
- 39449 Generic livery (single door)
- 39489 Metrobus red (dual door)
- 39492 Generic livery (dual door)
Outside of the peaks Aztec West isn't going to generate a lot of demand and the peaks are covered by Stagecoach so hourly direct and every 20 minutes round the houses sounds OK
You've made two posts complaining about the timetabling then you say you haven't studied the timetable! If the timetable is bad it's First's problem, if it cant be kept to then it's likely the real problem is elsewhere.Well I haven't studied the timetable. You would need to be a frequent user of services between Gloucester Road and Centre really, to see just how bad it is now. A lot of times the services aren't operating as the timetables suggest they are. Very very often there are gaps of 10 minutes or more when I'm waiting for buses between Zetland Road Junction and Haymarket in either direction. Have lost count of the times I've walked down Zetland Road intending to get a bus on Cheltenham Road towards Centre, and then I see two buses going down together, and then another one just after. "Oh no! That's three buses I've just missed. Will probably have to wait about 10 minutes for the next one now!" I think to myself. And yes, I get to the bus stop and the live display says next bus in 9 minutes or whatever. I've now started checking the live departures display before I leave my house to try and avoid this frequent annoying problem. Before, there was never usually any need to do this for a journey along that stretch. Another example, on an evening last week waiting for a bus at the Haymarket, the live departures display says a 71 in 12 minutes, a 73 in 12 minutes, and a 75 in 15 minutes! A 12 minute wait for a bus, and three buses practically bunched up together!
It was never as bad as this up until the September 2019 changes. Up till then it was usually never(with exception to early mornings, late at night or on Sundays) more than about a 5 minute wait for any service between Gloucester Road and Centre in either direction.
They never used to be like that, but when they upped the frequency on weekday evening last major change they buggered it up completely!The 1 and 2 in the evenings are similarly poorly timed, being just 2 minutes apart then a 27-28 minute wait for the next two to arrive together.
Definitely! First's timetabling of late has been awful. I still can't understand why, just before the 18/19/19a changes, the 19 and 37 were scheduled to run exactly at the same time between Bath and Bitton - ridiculous!They never used to be like that, but when they upped the frequency on weekday evening last major change they buggered it up completely!
Some examples of poor timetables across Bristol Part 1 (Where services interwork) Part 2 will follow later!
75/76) From Hengrove run within 2 mins of each other, then 12/13 min gap, although from Bedminster to Horfield should run every 7/8 mins, then at peak times for some reason they bunch up to run within 2/3mins then a 10/12 min gap!
1/2) Between 6am and 8am from Cribbs they are timetabled to run within 1 min of each other leaving a 10/12 min gap. Okay this does allow the services to run at even gaps along Whiteladies, but still it is an example of where they don't interwork well, although most of the rest of the day they run at more even intervals from Cribbs but run within 1 min of each other down Whiteladies ..... In the other direction they run quite well up until 9pm where they run together again for some bizarre reason!
T1/T2) Although they run very different routes, they both leave Thornbury/Centre at the similar times, T2 could do with being moved forward by 5 mins to fill the gap a bit better.
You have a list of 'problems' but don't actually suggest solutions to most of them. As colly405 has already said most of your examples are routes that diverge at various point then run together. Whoever provides the service then has to decide what the most important section is to have the regular frequency and which has to suffer. The only other solution is to have the service that's got the shorter route hang around for several minutes somewhere so that they're perfectly spaced at every point. I know how popular that would be!Some examples of poor timetables across Bristol Part 1 (Where services interwork) Part 2 will follow later!
A service has slightly sub optimal journey spacing running against the peak flow! The chances of any of the journeys being on time (when the schools are in) is 0 anyway! There are lots of things to have a go at First for, and areas where timetables could be improved without side effects, but this is pushing it!Indeed you're right. Take a look at this example of the timetable of the 75 & 76 from Colston Girls School towards Hengrove during the late afternoon/early evening.
Service 76 - time 1605, Service 75 - time 1616, 76 - 1617, 75 - 1628, 76 - 1629, 75 - 1640, 76 - 1641, 75 - 1652, 76 - 1653, 75 - 1704, 76 - 1705, 75 - 1717, 76 - 1717, 76 - 1729, 75 - 1732
Dreadful timetabling! These services don't operate at 7/8 min intervals at all times during the day! First definitely need to look into this and improve things. And the same goes for some of the other services mentioned too......
I will give a proper reply to this later. Explaining more in depth, as it can be done! Just needs some tweaking here and there.You have a list of 'problems' but don't actually suggest solutions to most of them. As colly405 has already said most of your examples are routes that diverge at various point then run together. Whoever provides the service then has to decide what the most important section is to have the regular frequency and which has to suffer. The only other solution is to have the service that's got the shorter route hang around for several minutes somewhere so that they're perfectly spaced at every point. I know how popular that would be!
TBH, the 75/76 running within two minutes from Hengrove is neither here nor there. They aren't the same route until they reach Bemmie via markedly different routes.I will give a proper reply to this later. Explaining more in depth, as it can be done! Just needs some tweaking here and there.
On another topic, I am surprised that the new timetables for April or what's actually happening (other than to the X3) aren't up yet.
Such enlightened times. It would have been time for a woodbine previously, or two if the result was to slot in behind another bus from Blackboy Hill!TBH, the 75/76 running within two minutes from Hengrove is neither here nor there. They aren't the same route until they reach Bemmie via markedly different routes.
Same with the 1/2 out of Cribbs. They want to be consistent over the central core part of the route but with differing durations between Cribbs and the Downs (33 mins vs 40 mins) and markedly different routes via Westbury vs Henleaze, it makes perfect sense to have them leave relatively closely together from Cribbs. I guess for the purists, the 1 driver could always be asked to park up in Westbury for 7 mins and read the paper
Good job 32003/4/7/9/14/15 keep on trucking!Bath suddenly really short of buses again! 10183, 33948 & 33950 all breaking down for the 2nd day in a row today (3rd day for 948).
Things so desperate that LH have leant 37357 over as cover!
And 008Good job 32003/4/7/9/14/15 keep on trucking!
