Kestral HS4000
Does anyone know why only Ipswich and Neville Hill are the only mpd's to receive their fuel by rail depots such as Doncaster and Beshford hall must use a massive amount
Rail fuel has been low sulphur since 1/1/2012 when the spec was virtually aligned with road diesel.Also bear in mind the source of the fuel. For example, Fawley stopped dispatching Gas Oil by rail after the plant was upgraded to produce low-sulphur product. (Esso's antipathy to rail must have had a bearing of course.) The new plant produced DERV only; Gas Oil was produced by Hamble from DERV piped under Southampton Water. No rail connection to Hamble any more, so . . .
BTW, before this Fawley did dispatch Gas Oil to depots as far as Peak Forest, due to their high-sulphur product being significantly cheaper than sources such as Lindsey, even though further away.
Pat
Crown Point has been served by road tanker since the early 1990s. It's not a problem really.Crown Point must be delivered by rail of have thought? There's only very limited road access.
Ipswich cannot be served by road in its current location.Does anyone know why only Ipswich and Neville Hill are the only mpd's to receive their fuel by rail depots such as Doncaster and Beshford hall must use a massive amount
The closure of wagonload services meant that traction fuel and many other less than trainload products were lost to road.It's cheaper by road![]()
Pat
The normal access is very tight underneath Trowse bridge, but there is a secondary access via a level crossing at the other end of the site.Crown Point has been served by road tanker since the early 1990s. It's not a problem really.
I wonder if Neville Hill might be to do with road access on site being a bit of a pain (or at least it looks like it would be). So bringing a full size articulated tanker might be quite a complex and difficult job versus bringing a small rake of rail tankers might be simpler.
Fuel by Rail to Freightliner, Ipswich, will end on completion of their new depot at 'Upper Yard'.Does anyone know why only Ipswich and Neville Hill are the only mpd's to receive their fuel by rail depots such as Doncaster and Beshford hall must use a massive amount
I think the point is that regular 3,000-tonne trains to Kingsbury are rather more efficient than occasional handfuls of wagons to a traction depot where they are actually an operational nuisance amid the main activity.Thanks for your ideas most of them i agree with but if Edders 23 is right (and I think he is) who subsidizes Kingsburys massive flows from LOR and CONOCO
Yes. Tankers & other larger lorries cross over Cremourne Lane level crossing outside Crown Point Panel signal box. Often there is a very long wait between trains/shunting.The normal access is very tight underneath Trowse bridge, but there is a secondary access via a level crossing at the other end of the site.
