Duncan-231192
This has probably been covered before, but I am not trawling through tens of thousands of articles.
So, the future of third rail. First, unlike many, I am not going to pretend that the third rail network is ever going to be converted to OHLE. It's not, and that is an end to it. But, it is a extremely inefficient system that needs updating for the 21st century.
So, the question is simple. What are peoples idea for improving the third rails networks for the 21st century?
Personally, I would progressively replace the old Steel Conductor Rail with an Aluminium/Stainless Steel Co-extruded replacement with a larger cross section. Aluminium has far higher conductivity than steel, even high conduction steel, and the hard stainless steel cap provides superior wear resistance than the current rail. This would reduce thermal/resistive losses, and/or increase the power which the conductor rail can carry. I would also replace the grid connections with modern, more efficient alternatives allowing higher efficiency and greater power availability. I wouldn't extend the third rail system westwards, but I would fill in the various gaps in the third rail network such as Marshlink Line, and Uckfield Branch
