southern442
What are the service changes during the Gatwick Airport station upgrade period? Is there any re-jigging of mainline service patterns or will it just be that a few services are cut and everything else is left as is?
Well obviously Covid has changed everything but if I remember correctly, the semi fast London Victoria - Brightons were withdrawn. The two Gatwick Express Victoria - Gatwick Airport services were also withdrawn. The other two Gatwick Express services were rebranded as Southern services and run through to Brighton all day also calling at East Croydon.What are the service changes during the Gatwick Airport station upgrade period? Is there any re-jigging of mainline service patterns or will it just be that a few services are cut and everything else is left as is?
Ah I see, so was this going to happen anyway regardless of COVID?Well obviously Covid has changed everything but if I remember correctly, the semi fast London Victoria - Brightons were withdrawn. The two Gatwick Express Victoria - Gatwick Airport services were also withdrawn. The other two Gatwick Express services were rebranded as Southern services and run through to Brighton all day also calling at East Croydon.
The Vic - Littlehampton's/Eastbourne's no longer split and join at Haywards Heath and have been seperated out to become their own individual services.
Anyone correct me if I'm wrong.
This is because Platform 6 at Gatwick is closed and train cannot call at Platform 5 at the minute.
Yes it was. The Eastbourne service should be half hourly along with the Littlehampton service although the reduced timetable due to Covid and the Salfords landslip may have caused this to go down to hourly temporarily.Ah I see, so was this going to happen anyway regardless of COVID?
I remember at the beginning of the pandemic, it was hourly to each of Littlehampton and Eastbourne, with the Littlehampton train also replacing a Brighton to West Worthing service too, stopping at all stations from Burgess Hill onwards, which must've been fun! Now it seems the 'Mainline East' service remains hourly but carries on to Ore, and the Littlehampton service is now half-hourly, which means there is an overall 3tph reduction in services on the BML rather than 4tph if they had kept both hourly.
I'm not sure but I can make a strong guess it was to improve reliability. Yes it would as that's what happened pre Gatwick Works.I actually rather like this form of the timetable to be honest, in particular the Victoria to Brighton fast stopping pattern is quite a sensible one to me.
What was the reason for splitting the Littlehampton and Eastbourne services? If they ran together would it allow for a slower Brighton service to be added?
That makes sense, I suppose with reduced capacity the dividing at Haywards Heath has the potential to really screw things over. The one thing I think the BML needs would be a Brighton stopper that calls at Clapham Junction and Redhill, as that would give Redhill both a (regular) fast service to London and a (regular) link to the coast once again. But that's going a bit off topic methinks.I'm not sure but I can make a strong guess it was to improve reliability. Yes it would as that's what happened pre Gatwick Works.
No it doesn't (at least from the point of view of passengers south of Gatwick). Running via Redhill is unreliable, requires two conflicting moves on each service, is difficult to timetable and extends journey times for passengers on the Brighton line. The Horsham to Peterborough service gives Redhill a reasonably fast service to London.That makes sense, I suppose with reduced capacity the dividing at Haywards Heath has the potential to really screw things over. The one thing I think the BML needs would be a Brighton stopper that calls at Clapham Junction and Redhill, as that would give Redhill both a (regular) fast service to London and a (regular) link to the coast once again. But that's going a bit off topic methinks.
I do think that the Horsham train should skip Merstham and Coulsdon South and give those stops to the Gatwick train, to create a better fast/slow pattern for Redhill travellers. A Redhill stop on a coastal service would make things tricky but it wouldn't extend any journey times for anyone using the fast service, and it perhaps could be done if it travelled on the slow lines north of Three Bridges. But then again it doesn't have to run. I was under the impression that Redhill and it's passengers felt hard done by when they got rid of the coastal services, but if there is no demand for it then obviously it would be more trouble than it's worth.No it doesn't (at least from the point of view of passengers south of Gatwick). Running via Redhill is unreliable, requires two conflicting moves on each service, is difficult to timetable and extends journey times for passengers on the Brighton line. The Horsham to Peterborough service gives Redhill a reasonably fast service to London.
I remember seeing a Littlehampton & Eastbourne train at Clapham (front 8 for Littlehampton, rear 4 for Eastbourne) and the back unit was already rammed!Part of the attraction of removing splitting at Haywards Heath is that there were times when the demand was enough for an eight car train from both routes. Clearly that is not a problem any more but the decisions were made before March 2020.
Funnily enough, 2x377/3 was a fixture on Brighton fasts when they were first introduced as it enabled two 6-car trains to go into London in the evening peak and come back out as 12-377 to Brighton. As you note, 8 and 4 didn't always work on the Coastway services prior to March 2020 (and I don't think 6 and 6 necessarily would have done either).Perhaps 2x377/3's might have been a good idea in another universe?
Yes, they do feel hard done by. There was pre-March 2020 demand as well but it is a trade off between having trains you can board at Redhill or cramming aboard trains that are already full with passengers from the coast and the operator has decided not to provide these services.I was under the impression that Redhill and it's passengers felt hard done by when they got rid of the coastal services, but if there is no demand for it then obviously it would be more trouble than it's worth.
I personally am quite content that the pattern actually gives a good balance between the two services which is actually better than a fast/slow pattern for most stations and it seems to fit with the rest of the timetable at Gatwick. The Gatwick works are really about the passenger facilities rather than timetable flexibility so I guess the timetable is fairly fixed for a while, especially if the Croydon works get called off.I do think that the Horsham train should skip Merstham and Coulsdon South and give those stops to the Gatwick train, to create a better fast/slow pattern for Redhill travellers.
Because the 377s are 4 cars if you split Littlehampton/ Eastbourne one will be 4 and one 8 cars. The 4 cars on the Littlehampton have been overcrowded for years. Its not usual to stand to have to stand between Haywards Heath and Shoreham with the end of splitting all the services are timetabled for 8 cars.I actually rather like this form of the timetable to be honest, in particular the Victoria to Brighton fast stopping pattern is quite a sensible one to me.
They've reduced it to just one during off-peak hours. The Ore - Victoria - Ore service.Eastbourne to victoria there are two trains per hour. At the moment .
While the amended Gatwick Airport works timetable has been in use, what has the reliability been like for the Southern services?I think it will be very unpopular to go back to the old operation.
It might be hard to gauge with covid-19 reducing passenger numbers.While the amended Gatwick Airport works timetable has been in use, what has the reliability been like for the Southern services?
With the end of trains joining/dividing at Haywards Heath, is the service more reliable?
And judging by the comments above, it seems long overdue to have seperate Littlehampton and Eastbourne services.
There's still people travelling thoIt might be hard to gauge with covid-19 reducing passenger numbers.
I think reliability has generally been okay?While the amended Gatwick Airport works timetable has been in use, what has the reliability been like for the Southern services?
Covid.Is the Tattenham Corner service being reduced to an hourly shuttle to Purley to do with this timetable, or is that a COVID thing?
But not as many so one might hope more chance of trains being reliable, in terms of arriving and departing on time.There's still people travelling tho
