Wyrleybart
Engines in 66s are bolted straight to the frame. If you drive them you feel the vibration therough the DSD pedal.That’s no different from a 66 in terms of engine mounting, is it?
I would suspect so but I don’t want to make any unwieldy claims. I’ve heard that by 0100 on Monday all 69s will be off GBRf TOPS and back to EMD but I can’t prove that.This sounds like they'll be out of action until a modification can be designed and installed?
As per a different thread they've been stepped down, although some say this is from Monday. Probably off it to avoid any potential issues arisingThis morning Mountfield gypsum working was allox to a 66. I thought this service was a core part of the 69's workings since they entered traffic.
If they are not immediately stopped, it suggests there are no safety issues then.I would suspect so but I don’t want to make any unwieldy claims. I’ve heard that by 0100 on Monday all 69s will be off GBRf TOPS and back to EMD but I can’t prove that.
Most of the 56s were not in a serviceable condition anyway. 104 and 312 might have been runners with a bit of work, but only 081 and 096 have been operated under GBRf ownership.If they are not immediately stopped, it suggests there are no safety issues then.
Always thought it optimistic to order sixteen in two batches without any serious in service results from the first couple. The old German / European concept of building four of five of a prototype batch, then refining the design for a series class seemed like a good idea to me.
That thread has been merged into this one. The relevant messages are a page back from here.As per a different thread they've been stepped down, although some say this is from Monday. Probably off it to avoid any potential issues arising
that's difficult to visualiseReportedly, the main reason for the swift withdrawal is that the crack may have split the crankshaft because of the 69’s lack of engine mounts or dampers. Also the remaining 56 conversions are on hold indefinitely so 081 and 098 are saved for now!
I can’t say I’m surprised to see build quality and arising work listed. Some of the quality of the welding and painting (not the main job carried out by Arlington but the chassis stuff carried out during the rebuild) has certainly been somewhat poor. You only have to see the locos on their transit moves to Eastleigh to understand what I’m talking about!GBRF have issued this press statement: "GBRf Class 69 Following introduction of the class 69, and learning from the initial service phase of operation as well as build, GBRf and EMD are taking an opportunity of a change in traction requirements following winter operations to carry out a number of reliability, build quality and cab improvements to the class 69 fleet. These improvements include to the cab environment, new drivers seat, build quality and arising work. We are working with our supplier EMD to complete this as quickly as possible as a fleet wide program".
I might do, I have no knowledge of what goes on in engines. This is just from sources I’ve had - hence ‘reportedly’that's difficult to visualise
do you mean crankcase?
I have not seen any piccies published online to suggest any chassis stuff is iffy. The paint obviously has only been intended to get the locos from Longport to Arlingtons and there is no doubt the latter company have had to do a lot of prep on the bodyshells to get the paint finish good.I can’t say I’m surprised to see build quality and arising work listed. Some of the quality of the welding and painting (not the main job carried out by Arlington but the chassis stuff carried out during the rebuild) has certainly been somewhat poor. You only have to see the locos on their transit moves to Eastleigh to understand what I’m talking about!
Longport I supposePresumably the 69s have been stopped more or less where they were.
Are there any in Tonbrodge Yard - and if so which ones? I'm thinking of taking a trip to Tonbridge in a couple of weeks (half term hols), but that's dependent on what I'll find there.
And I'm wondering where the rectification work will be undertaken ... my guess is Stoke? But could it be done elsewhere - eg Eastleigh?
Many thanks
001, 003, 006 and 007 are apparently on their way from Tonbridge to Peterborough this morning.
002 and 004 left in Tonbridge
(according to local gen group)
Many thanks guys.Based on reports elsewhere, it does appear that the 69s already delivered will have their retrospective work undertaken back at Stoke.
There's an article today on Rail Magazine claiming there's no hairline cracks and the main problems are water egress and engine noise:
Technical issues cause GBRf to withdraw Class 69s
GB Railfreight has confirmed that it has temporarily withdrawn its entire fleet of Class 69 locomotives in order to investigate faults being reported by driverswww.railmagazine.com
Water egress? I've read the article linked and it certainly says this, but where is the water escaping from, that's an odd one; the power units? Do they actually mean ingress, which would be a driver issue?
I suspect the water loss is between the engine and the radiator(s)?
Should mean it's a lot quicker and easier to fix them, then?There's an article today on Rail Magazine claiming there's no hairline cracks and the main problems are water egress and engine noise:
Probably I would think, never heard anyone say "water egress", you'd usually reference something leaking out by using the word leak!Or maybe they meant ingress but messed it up.
Semantics to dumb-down the problem I suspect?Probably I would think, never heard anyone say "water egress", you'd usually reference something leaking out by using the word leak!
I agree - I suspect it's most likely a typo/autocorrect/autocomplete error and should say 'ingress'.Probably I would think, never heard anyone say "water egress", you'd usually reference something leaking out by using the word leak!
